What is this lever on my steering column. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 03:34 PM
rusthater89's Avatar
This is on a 78 Firebird.
Old 08-16-2012, 03:49 PM
delawarebill's Avatar
lever
its the shift lever that attachs to the tranny.. ck your column and see if someone cut it off inside the car, then someone put in that column..after the car was done.. u have floor shifter for auto on yours..
Old 08-16-2012, 04:28 PM
LATECH's Avatar
Floor shift cars back then still had the rod to the steering column to turn the upper collar by the key . They just eliminated the shifter on the column, but the moving parts for the ignition and shift lock will still there and were functionable to provide security .
Fact is stranger than Fiction
Old 08-16-2012, 04:29 PM
Oh, so you are saying it is for a steering column shifter? I guess since I have a floor shifter it is pretty much useless. I guess that is not the original steering column either?
Old 08-16-2012, 04:32 PM
Do you mean security as in keeping the steering column from impaling me in a wreck?
Old 08-16-2012, 04:41 PM
poncho62's Avatar
Wiki Edits: 5
No...he means that the shifter has to be in a certain position for the car to start etc, as in neutral or park
Old 08-16-2012, 05:35 PM
It was meant for a link that prevented shifting from park with column locked.
Old 08-16-2012, 07:31 PM
But it only applies on a column shifter. I noticed the floor shifter I got does not lock at all.
Old 08-17-2012, 07:40 PM
If you connect that to the transmission, it will lock the floor shifter too.
Old 08-18-2012, 02:00 AM
As they did in Grand Prix and other higher-priced models...
The Following User Says Thank You to hardhatz For This Useful Post:
Tbooks (09-03-2012)
Old 08-18-2012, 03:12 AM
Safety interlock. On some cars(like mine), this also controls the back up lights and nuetral safety switch.
Also a theft deterant, the key only comes out in park, and the shifter is locked in park
The column has to be broken to be able to shift the car out of park.
If it doesnt interfere with your exhaust, or any othre mod, I'd find one and reconnect it.
Oh yeah, it prevents the steering from being locked unless the car is in park. Right now the car could be shut off while in motion.
Old 08-18-2012, 11:51 AM
Interesting, I always thought the car just did not have back up lights and I could just start the car up in drive, came in handy when my cold engine stalled out at stop signs. I also found it neat how I could leave the engine running and pull out the keys so I could open the trunk.
What does the part look like?
Old 08-19-2012, 01:27 AM
Its called a back-drive assembly, I'd check local salvage yards to get the whole thing. Consists of a couple of rods, shift lever,(might still be on transmission) frame bracket(may still be on car)
Here's the whole assembly from a GTO. Firebird is probably a little different(shorter) Some of these parts can be sourced thru Reproduction companies like Year One, NPD, etc.
Old 08-19-2012, 04:24 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
WINNER, WINNER Chicken Dinner!!!!!
As FRMSTRRACER said it's a back drive system. From 1969-thur the 80's at least GM cars. That arm was on both auto and manual trans. It controled the key lock, steering wheel lock, nuteral safety switch, and reverse lights switch.
Old 08-19-2012, 04:42 PM
SSedan64's Avatar
Also on G-bodies with floor shift, the gear position indicator is in the dash instead of on the console. This also moves the gear indicator, string attached to column.
Diagram for F-body parts:
http://gmoem.com/pontiac/1978/firebi...bsp_p4_20.html
Name:	G-body Shift Indicator 1.jpg
How to wire column shift light in flaming river steering column firstgear Electrical 6 03-02-2012 10:14 PM
inner downshift lever and inner manual lever. C6 ekacpuc Transmission - Rearend 1 12-28-2011 08:38 PM
my new turn and stop signal lever (mt's on column) 39chevy Electrical 2 02-03-2008 12:30 PM
Tilt steering lever - 2000 Malibu - NOT Hotrod heyjude076 Suspension - Brakes - Steering 4 03-01-2007 11:07 AM
Convert multi-function signal lever to plain lever? murrsue General Rodding Tech 0 03-07-2005 07:56 PM
