What to look for chevy ii - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2013, 08:26 PM
Hi everyone,
I'm new here and joined because this is the most complete forum I found.
Question
I' m about to trade for a 1965 chevy ii nova, wanted to know what faults should I look for more specifically what places on the car are the most affected by its age. It has a 230 engine,runs great, floors and trunk are in great shape.
Any suggestion on what else to inspect.
Thanks in advance.
JoePR
Old 08-19-2013, 08:33 PM
Wiki Edits: 27
up time
Get it up on a hoist and look for and rust areas or recent coating of goo-undercoat. poke with a screw driver looking for rust thru or poke thru areas then the general safety check, hoses, brake lines fuel lines, exhaust. etc.
Old 08-19-2013, 08:56 PM
carolinacustoms's Avatar
Automotive Extraordinaire
I would check the inner rockers, floor pans from the bottom, etc As stated, any new undercoating or paint may be a cause for concern. If the car has been recently painted and you are concerned, you can buy a thickness gauge pretty reasonable to check it out a little bit (a small magnet will also serve the purpose, just don't drag it on the paint or it will scratch it)
Paint Thickness Meter Gauge Bit 3003 Crash Test Check 2 Years Warranty | eBay
Kelly
Old 08-19-2013, 10:56 PM
vinniekq2's Avatar
The front ends in ChevyIIs are weak and should be checked closely.Inspect around the shock towers. I would also look around the leaf spring perches.Front lower control arms bend easily.The cars steering is poor and the handling is poor. Brakes are fair at best. fun cars,but they need tlc
The Following User Says Thank You to vinniekq2 For This Useful Post:
carolinacustoms (08-20-2013)
153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick. Classic Chevy Dave Engine 2 09-17-2010 03:44 PM
newer chevy distributer in older chevy car,what are these four plugs? gearjammer38 Electrical 11 08-09-2010 10:15 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 10:40 PM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
Will this work? Chevy 305 Throttle Body w/ Chevy 350 aberg12012 Engine 9 05-07-2004 12:28 AM
