Check the next filter to see if it is the same
Artificial Intelligence is no match for Natural Stupidity Chet |
Cloth rag lint from rags used during assembly? Moly lube would be my other guess.
Ahhh...good thoughts on the molylube. Not sure what kind I used, but I did use some cam lube on the cam lobes and lifters and also some assembly lube on the bearings.
The black stuff is not firm enough to be RTV, plus the wrong colour from what I used. I do use Permatex Aviation Sealer (formerly Indian Head gasket shellac), but it's quite impervious to oil, although I thought maybe hot oil might dissolve some. I did have a very small amount of gray paste in the bottom of the filter. No significant amount. Maybe enough I could make a couple of fingerprints from it. Some of it rose up when I got a magnet near it, so that would be ferrous and no doubt left over residue from the machine work that didn't get completely cleaned up. The gray is probably a little bearing wear from break-in. And it could be a little lint from a cloth or paper towel from when I wiped down the cylinders. Overall, I'm pleased to see nothing (I think ) of any major consequence.
Curious-what kind of filter is that?
It's a System 1. Benifits are you can take it apart to see what's inside. You can cut a paper filter apart, but then you wonder if the little bits you see are from the filter case when you cut it apart....unless you happen to own a filter cutter (like a industrial looking can opener). The System one flows really, really well, so very little pressure is lost across the filter. This also helps keep the bypass from opening when the oil is cold, or at high rpms. It can also help increase hot idle oil pressure a little bit.
On the not so nice side, they are a pain to clean, plus the lowest stainless steel filtering screen they offer is 30 microns. Not sure how bad that is as paper filters rated at 15 microns can still pass a 50 micron particle, while the System 1 won't pass anything larger than it's rating. Paper filter ratings seem to be based on a percentage of what gets through. I've been told not to use a cleanable filter for break-in, but to use a good paper one to filter out all the fine bits from break-in wear. However, I'd rather not have any of those larger bits get through the filter internal bypass during break-in either, and that would seem to be more likely with a paper filter. Here's a link: http://www.system1filters.com/oil_filters.htm |
Could it be a combination of carbon/ fuel/ oil mixed together from blow by ?
It's kind of odd. I did a Google search and there's a ton of info on cutting open oil filters, but nothing much is mentioned about what to look for. I guess most people are just looking for those obvious metal bits. |
Gather some of it up and see if it burns or glows (slow burning), that will tell you if it is paper or cloth lint.
Keep reducing the possibilities and you'll have your answer. Nice filter! |
| Daily funny--- Revisited | schnitz | Off-Topic | 2950 | Today 11:23 AM |
| Oil filter stuck | joefromcocomo | Engine | 9 | 03-28-2010 09:56 PM |
| 454 BB Oil Filter Conversion | Blanceman | Engine | 3 | 02-27-2010 07:35 PM |
| Oil change nuisances | Slipangle | Hotrodders' Lounge | 13 | 10-09-2009 03:32 AM |
| Should I change my oil? | 48Man | Engine | 2 | 01-29-2003 07:28 AM |
