what to look for when buying Plasma cutter - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-08-2013, 09:33 PM
life is a temporary assignment
Make sure you buy a good drag tip as well.. A reg tip, you need to hold it off the plate your cutting.. You can drag them, But they won't last as long as a drag tip..
  #32 (permalink)
Old 12-10-2013, 06:13 AM
deadbodyman's Avatar
Wiki Edits: 11
Thats very helpful ,I didnt know there were different tips..
How long do the tips last and how do you know when to change them
  #33 (permalink)
Old 12-10-2013, 06:41 AM
I did not know there were different tips. I am still on my first tip but as I said earlier I am pretty carefull not to let it drag on the surface and use a guide that holds it just slightly off the surface.
John
  #34 (permalink)
Old 12-10-2013, 06:50 AM
Wiki Edits: 11
John
John ,I guess you'd be the one to ask if it cuts through rusty metal well...
The Following User Says Thank You to deadbodyman For This Useful Post:
tech69 (12-11-2013)
  #35 (permalink)
Old 12-10-2013, 07:55 AM
BOBCRMAN@aol.com's Avatar
Just about all the material over 3/8" thick that I cut is recycled/rusty or painted. Start cut on a relatively clean spot and the cut will be good.
When the tip gets worn, there will be a "pit" in the center of the inner electrode. Or the orifice will not be round. Makes the kerf wider and not as smooth.
  #36 (permalink)
Old 12-10-2013, 08:40 AM
Yes.. they do have different tip's..
https://www.google.com/#q=drag+tip+f...utter&tbm=shop
My machine will let you know when you need a new tip..
  #37 (permalink)
Old 12-10-2013, 10:03 AM
I have not cut a lot of rusty metal with mine but I did cut off the bottom of the toe boards and it did fine. I have read that the Pilot Arc models are better for rusty metal but don't know enough about the technoligy to address that.
John
  #38 (permalink)
Old 12-10-2013, 10:56 AM
Most all the new technology units are pilot arc.. I notice it on mine when someone forgets to plug the air source in..
  #39 (permalink)
Old 12-11-2013, 06:10 AM
Wiki Edits: 11
It should be here on friday...If so I'll have all weekend to play with it..it said it'll cut 4.7 " or 12mm ,that seems like pretty thick stuff for a cheapo cutter, it should be very handy for making brackets and mounts...
  #40 (permalink)
Old 12-11-2013, 06:18 AM
You will really love it, I am sure. I sure hope it does well for you.
And....You got it in time for this years taxes,
John
  #41 (permalink)
Old 12-11-2013, 06:39 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
That IS very thick material to be cutting with a plasma....
You'll become dependent on it very quickly. I wear dark safety glasses when cutting to better watch the cut line and still be able to see when I'm done. It's like using a torch without goggles. I tried using my auto welding helmet on 9 but it's too dark to see well.
  #42 (permalink)
Old 12-11-2013, 06:47 AM
Wiki Edits: 11
oops ,thats .47"..... I'm going to build a 6' brake using the cutter to make all the parts...should be an interesting project...
  #43 (permalink)
Old 12-11-2013, 07:02 AM
You realize, of course, we will require pictures...........
  #44 (permalink)
Old 12-11-2013, 02:45 PM
Wiki Edits: 11
Of coarse ,John......,I'm still looking for detailed blueprints to buy but it'll be a box/pan brake with adjustable fingers for sure....
  #45 (permalink)
Old 12-14-2013, 07:22 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I guess it goes without saying, Dry air, Dry Air,is a must,
Mine is a Snap On (Century ) same as Sears,i have not had to replace my tip yet I have had it about 10 years but don't use it that much anymore.
plasma cutter michael cook Garage - Tools 38 07-06-2009 11:22 AM
Using a Plasma Cutter... S10xGN Garage - Tools 15 03-13-2008 07:09 PM
plasma cutter Holder350 Garage - Tools 13 10-30-2007 09:07 AM
plasma cutter hallewis Garage - Tools 5 11-13-2005 09:31 AM
I need plasma cutter help willys36@aol.com Garage - Tools 11 06-20-2004 08:03 AM
