what to look for when buying Plasma cutter - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 12-14-2013, 08:57 AM
Never thought about that! An air supply full of water would be big problem! Interesting discussion here.
  #47 (permalink)
Old 12-14-2013, 09:25 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Anyone using a compressor with air tools, blasting cabinets and such should already have a good moisture management system in place. I don't have a dedicated dryer in line. I have a 60 ft run of black iron pipe along the ceiling for cooling with 3 drop t's and ball valve drains every 20 ft along with the ball drain at the bottom of the tank. With regular maintenance, the air out the end of the hose is usually as a dry as a pop-corn fart...
  #48 (permalink)
Old 12-14-2013, 12:35 PM
Hmmmmm, You know what the next question is........
  #49 (permalink)
Old 12-14-2013, 01:20 PM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by NEW INTERIORS View Post
Make sure you buy a good drag tip as well.. A reg tip, you need to hold it off the plate your cutting.. You can drag them, But they won't last as long as a drag tip..
Randy can you post a pic of the two tips so we can see the difference...The ones that came with the cutter are concave ,I guess so the center of the tip dont actually touch the workpiece but the edge will make contact to get everything started...
  #50 (permalink)
Old 12-14-2013, 01:26 PM
Wiki Edits: 27
old torchmate ?
Next you will want a pattern cutter, I made one about 15 years ago like the ones advertized 30 + years ago for my ox-acety system . I used a ford windshield wiper motor that i made a longer knurled shaft, then used a vary-ac controller and an older battery charger. Rotten leonard now sells a kit for a plasma , but manually move it.
http://www.rottenleonard.com/Plasma-Tracer.html
The Following User Says Thank You to timothale For This Useful Post:
deadbodyman (12-16-2013)
  #51 (permalink)
Old 12-14-2013, 01:29 PM
Wiki Edits: 11
Originally Posted by 496CHEVY3100 View Post
I guess it goes without saying, Dry air, Dry Air,is a must,
Mine is a Snap On (Century ) same as Sears,i have not had to replace my tip yet I have had it about 10 years but don't use it that much anymore.
I gota great air supply...One thing I noticed that got me thinking was where the air goes into he unit it says "gas" ,I remember being at the metal fabricators, where I get my materials from and they were cutting with the cnc plasma cutter and they were using Oxygen ,it got me thinking what would happen if I were to use oxygen insted of air or if its even an option for someone that dosent have dry air...
  #52 (permalink)
Old 12-14-2013, 01:32 PM
I think you would have a very big fire! Is not one of the biggest causes of house fires caused by smokers who are using medical oxygen?
John
  #53 (permalink)
Old 12-14-2013, 01:35 PM
Wiki Edits: 11
Plasma-Tracer
Yup,I want to cut a lot of patterns.... I used some 1/4 hardboard as a pattern...it works like a woodworking router and follows the pattern. whats yours look like??? oops nevermind I just clicked the link....
  #54 (permalink)
Old 12-14-2013, 02:10 PM
You want to know how dry a popcorn fart is ???
Eat some popcorn...
Pure oxygen might make the flame point hotter ??? Don't know why they would use gas with a flame cutter. Like John said anything flammable would be a hazard...
  #55 (permalink)
Old 12-14-2013, 04:28 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Iam not fimilar with the new Plasma cutters but mine came with a dyer and a regulator attached to the rear of the unit and one on each outlet line and it has a automatic bleeder to help keep moisture to a minimum,,i guess it is the humidity out here but almost all compressors produce water =we drain 2 or 3 times a day when all the compressors are running,,it is probably dry enough on the left coast so you don't have to worry like we do out here
  #56 (permalink)
Old 12-14-2013, 04:37 PM
BOBCRMAN@aol.com's Avatar
In Michigan we are surrounded by water on three sides, always humid and always draining water traps.
The water trap/regulator on the back of my plasma machine never gets water so I guess my air system takes care of the problem well.
  #57 (permalink)
Wiki Edits: 11
John
OMG....smoking....in bed.....WITH medical oxygen....
I just had my acetylene and oxygen tanks filled ....the big ones too.
  #58 (permalink)
Old 12-14-2013, 05:36 PM
The port that says Gas is used on the models of machines that also TIG weld. They use that port for shielding gas. As well as air.
  #59 (permalink)
Old 12-14-2013, 06:20 PM
I bought the lotos off of ebay a couple years ago and I love it. You may want to consider the pilot arc as it doesn't require the metal to be clean, it can blow through rust or paint but the consumable are much more expensive. I was able to easily cut a piece of rusty 1/2" steel in two, about a foot long and it made a really nice cut.
Jeff
  #60 (permalink)
Old 12-15-2013, 06:51 AM
Wiki Edits: 11
how does the pilot arc work? I dont know if thats what I have or not..
How do you turn your plasma cutter into a tig welder?
plasma cutter michael cook Garage - Tools 38 07-06-2009 11:22 AM
Using a Plasma Cutter... S10xGN Garage - Tools 15 03-13-2008 07:09 PM
plasma cutter Holder350 Garage - Tools 13 10-30-2007 09:07 AM
plasma cutter hallewis Garage - Tools 5 11-13-2005 09:31 AM
I need plasma cutter help willys36@aol.com Garage - Tools 11 06-20-2004 08:03 AM
