What main cap girdle would you recommend for a chev 400 with a 2 bolt main - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2002, 12:13 AM
banned
Post What main cap girdle would you recommend for a chev 400 with a 2 bolt main
Yeah so anyways... I was just wondering what you guys recommend for small block chev 400 with 2 bolt mains as far as main cap girdles.. I would like something reasonably priced but good quality.. any links would help
Old 12-29-2002, 12:24 PM
banned
Post
I will just bump this to the top
Old 01-02-2003, 10:45 PM
New Member
Post
Why not use Millodon splayed billet 4 bolt main caps? its about $185 take the block down to the machine shop they will drill and tap the block for it then line hone the block. After that you wont need a cap girdle. about 100 for the drill and tap and 100 for the line hone.
Old 01-02-2003, 11:07 PM
banned
Post
well cuz girldes are stonger (to my knowledge) and they don't weaken the webbing
Old 01-03-2003, 06:36 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
A 4 bolt spayed will be stronger than a 2 bolt with a girdle.
Luv the smell of NITRO in the morning.
Old 01-03-2003, 08:13 AM
E.T. divided by $ spent= Speed
Post
How much power are you makeing,that calls for reinforced mains??
Old 01-03-2003, 01:51 PM
banned
Post
Not all that much but putting like 350 to 400 hp to a 2 bolt scares me... I know you aren't supposed to worry till 600 but I want to put the gridles on just in case.
Old 01-03-2003, 04:25 PM
NAIRB's Avatar
Post
400 horses with a 2 bolt main is nothing, I wouldn't let that bother you one bit.
Old 01-03-2003, 10:39 PM
banned
Post
OKay but I am still interested in main girdle does anyone have any info?
Old 01-04-2003, 12:34 AM
Post
Sorry, I think this is a waste of time and money. Two bolt main 400 small blocks do not have main cap walking problems with reasonable horsepower levels. I know a few peopele that drag race 400 small blocks with little or no modification to the block and they live at 6500-7000 rpm making 400-500 horsepower. Money would be better spent for heads and intake system.
Old 01-04-2003, 01:29 AM
4 Jaw Chuck's Avatar
Post
Spend the money on better rods Dave, thats the 400 SBC weak point. If you want to strengthen the bottom end then put ARP studs in, thats all you will need.
— Han Solo
Old 01-04-2003, 02:49 AM
banned
Post
Umm how much would new rods be for same length as stock.. who makes the best?
Old 01-04-2003, 07:41 AM
Post
Don't use the short 400 rods. Use a good 5.7 or longer rod. They produce less side loading on the cylinder walls. Be sure and add good rod bolts.
They should be okay for 400 to 500 HP.
Old 01-04-2003, 02:52 PM
Post
Who makes the best? Carrillo.
Old 01-04-2003, 03:37 PM
NAIRB's Avatar
Post
Crower, Carillo and Oliver are probably some of the best you can buy.
