what max psi do you set your compressor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2010, 11:32 AM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
I just blew my second regulator. I don't know if it was because they were cheap or my compressor setting is too high.
How high is high enough? It's a two stage CH with an 80 gallon tank. I use it to run auto body air tools so I need a steady supply.
Old 09-25-2010, 12:02 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I set mine as high as it will go and if you are blowing regulators then you need a better one..the ones from HF are not all that good..
I get mine from Motor Guard as those guys know their stuff and their regulator and water trap will be one of my shop air upgrades..I use a regulator then a water trap and then the M-30 toilet roll filter and set my pressure at 100 psi at the wall.
Sam
Old 09-25-2010, 01:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
When you say "regulator", are you talking about the pressure switch that handles the line voltage to the motor and switches the motor when required? Or a device that regulates the pressure downline from the compressor?
I've used Square-D pressure switches in the past, w/o problem. They are bought in "ranges" of the Off and On settings, w/some that are adjustable within those ranges. If they are selected correctly, they shouldn't be "blowing", IMO.
If you are blowing the pressure regulator that actually regulates the pressure from a high psi to a lower psi, they shouldn't be "blowing", either- as long as they are of a decent quality and sized according to the application.
I would be curious to know exactly what is happening, and what part it's happening to.
Old 09-25-2010, 02:46 PM
Wiki Edits: 29
It's the in line air pressure regulator. I just got back from the store about an hour ago. I had my receipt for the one I bought in 2001 but not for the other I bought around 2005. Customer service said the 2001 was past warranty but they would let me have two more at half price each. That was good enough for me. I have two because I have two couplers in my line.
These new ones say they service up to 160 psi. I have my compressor set to stop around 140. So I guess I'll hang on to the receipt and have another visit with them in 2015.
Old 09-25-2010, 06:59 PM
You really only need one regulator. Mine has a female quick connect on the out side and male on the in side. I just plug into any outlet and I have many and connect the hose. Simple.
Old 09-25-2010, 08:05 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I run 140 psi kickout on my compressor and as long as I use a quality regulator I don't have any problems . BTW , some regulators don't like being run down all the way so I have a female quick connect before and after the regulator and male quick connect on the hose going to my hose reel so I can switch in a jiffy if I want full pressure and volume for my impact on a stubborn bolt .
Old 09-25-2010, 08:16 PM
2ndchanceauto's Avatar
body and paint guy
Last journal entry: delivered
with the trigger pulled on a air blower i set mine at 90 psi. never needed more
Old 09-25-2010, 08:33 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I had to have 140 psi with my earthquake 1/2' impact to break the front axle nut loose on my 2006 1500 Silverado.
Old 10-06-2010, 11:57 PM
I have my 165 compressor turned to shut off at 150, because my regulators are 150 max.
Old 03-01-2012, 05:33 AM
New Member
I found this post is very informative. It has nice information about compressor. Thanks for sharing!
Old 03-01-2012, 09:25 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Back to the original question ..
The higher the pressure that you have in your tank. the more cfm of air you have in reserve. Personally, I am limited by the pressure rating of my safety pop- off valve, which is 145 psi. So my compressor is set to shut off at 140 psi. Running 35 psi through the regulator for painting gives long cycle time between the compressor running. Just saying what works for me. Any good quality regulator should handle 140 psi inlet pressure. The cheap regulators ? Not so much . Big Al
Old 03-01-2012, 09:54 PM
Last journal entry: Finally some floor!
My compressor cycles at 150psi amd I have a full pressure outlet before and the rest of the outlets after the regulator which is set @ 90psi. Most air tool mfg's recommend 90 max for continuous operation so they get plugged in after the reg. My regulator has the push 'n turn adjuster for more pressure if needed, but this arrangement has suited me well for over 8 years and blown nothing (but air of course). Bob
Old 03-02-2012, 06:42 AM
Irelands child's Avatar
This is a pretty old thread but possibly due for resurrection for the many new folks here.
As far as pressure settings - mine has a 150psig shut off but seldom use that level of air pressure, trying to usually match the tool to its RATED pressure, therefore saving wear and tear and possible tool failure. Most tools are rated at something like 90psig, especially die grinders. More, that overspeeds them. DA's - probably 90 as well for most as mine is. Take a look at your tools and that nameplate will tell you. Exceeding that - tool companies will love to sell you a new one
Irelands child
Old 03-02-2012, 08:26 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Looks Like It Is Summed Up
With the information given in the last three posts, on this thread, I think all the bases are covered for even a newbie. Only other question I can think of, would be required hose diameter, which we covered in another thread. Happy to re-post if needed.
Big Al
Old 03-13-2012, 11:55 PM
New Member
Hey.....I need 200 CFM @ 3 to 8 psi to feed air stones in my indoor food garden. what size compressor will i need to run the stones 24/7. Looking forward to your reply.
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 07:11 AM
will this air compressor plan work? snorulz Garage - Tools 16 05-07-2012 11:34 AM
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 03:01 AM
air compressor maintenance CaPrI_MaN Garage - Tools 8 10-04-2006 11:14 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 08:26 PM
