Might try a Chevette rear-end. They should be about the right width, and not too hard to find. People convert these to 2.8/3.1's pretty often and leave the stock rear-end alone. Parts wouldn't be much of a problem either. The gear ratio ranges from 3.83 to 4.11 in these cars...
The only thing that bothers me is, Chevette rears have this funny extension that comes out of the differential, about 2-feet, that the drive-shaft bolts to. Its like an old-torque tube or something that connects to the drive-shaft. It would probably be alright on your MG, but you wouldn't have much of a driveshaft. And they use coil-spings...that might be a problem too. Other than Chevettes, I'd say maybe a mini-truck rear or something, I don't have much else to say. -GF |
Many many moons ago me and my dad slapped a 351C in an MGA (MKIII no less
) we used the rearend out of a jeep (Dana 60) and didnt have to cut it, unfortunatly it was such a long time ago I dont remember the model or year of jeep.... just givin you another Idea possibly hit a 4X4 forum and ask around?
I'm told that the rear end from a Jeep mail vehicle is the correct size. You could ask that question here:
http://www.mgbexperience.com/phorum/list.php?40 http://www2.mgcars.org.uk/cgi-bin/ge...ect=36&thread= Greg |
I know that the 8" ford used in Mavericks is Ford's narrowest. Not sure how it compares to others, but disc brakes are possible with it and its pretty narrow. Gear ratios are limited in selection, but you can swap out the center housing for a 9" housing making a poor-man's 9" for the Maverick. Then your gear ratios are infinite... however your center section becomes very heavy and way overkill for your application.
If you can find a suitable ratio in a Ford 8" from a Maverick/Comet, that is Ford's narrowest anyway. |
This might help. I build T Buckets and a lot of guys use the 8" Ford but they are hard to find. We are using the rears out of S10 trucks. They are 54" wide from were each wheel bolts on. Just about all are 3.73 and some 4.10 and if you look hard you can find a posi. The junk yard here gets $100 for one.
| Thump Thump in rear end?? | HotRodMan | Suspension - Brakes - Steering | 7 | 01-24-2007 06:09 PM |
| 1975 8.5 rear end | camino_man | Transmission - Rearend | 6 | 09-18-2004 05:32 AM |
| Rear End Change | black66 | Transmission - Rearend | 4 | 01-28-2004 09:21 AM |
| Important rear end mounting question | 71gtx | Transmission - Rearend | 2 | 01-04-2004 06:05 PM |
| Ford 7.5" Rear End Traction-Loc Install | nightrain_rod | Transmission - Rearend | 2 | 12-30-2003 06:38 PM |
