Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what motors can i replace my 1964 pontiac 389 with
Old 09-05-2011, 10:02 PM
1badLemans's Avatar
1badLemans 1badLemans is offline
Vegas that one should work pretty good. The earlier blocks like 67-74 are the best because they pretty much bolt into all chassis with not alot of work. Get all the mounts and brackets from the 71 if you can and make sure the 350 is complete as possible. Some pulleys swaps on pontiacs can be a pain. If you just want to get your ride running and on the road, the 350 would be just fine especially if you can afford it and its close bye. Its not the most desireable and will not be a screamer but will power your car just fine untill you can get a bigger engine for some more fun!
