What are my options for Mopar B body disc brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 12:33 AM
adam83's Avatar
I need to swap out my front drum brakes on a stock 1971 B body Charger. Im not spending $800+ on a aftermarket swap until way down the line, so for now I need to know what my options are for a direct swap from another a/b/c/e body (as in, which setups will attach to my current upper/lower control arms). What other types and years of mopar cars have the front discs I want? What are my best options?
Old 03-18-2013, 06:53 AM
33Willys77's Avatar
Read this. Installing Factory-Style Disc Brakes - Mopar Muscle Magazine
Old 03-18-2013, 09:00 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Not absoluteley certain, but I think the Charger shares front end components
with a C body car.
I seem to recall the upper and lower ball joints being the same.
(this was back in the 80s)
I changed from factory discs on a 67 Chrysler (4 piston Budd) to discs from a 73 Plymouth Fury.-----Direct bolt in with no modifications.
(the 67 Rotors had been discontinued by '83, and the "Disc Brake" lower ball joints were over $100 each way back then-----swapped to 73 "C" body brakes for about $80 at the time.)
Later --rebuilding a 71 Charger front end, I realized it used the same parts as the 73 Fury.
Old 03-18-2013, 12:48 PM
Bryan59EC's Avatar
oh---I should also mention that in 74 all of the front end components changed
I don't think anything for a 74+ will work.
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
76 camaro disc brakes fitting 65 A-body Fastest65 Suspension - Brakes - Steering 7 04-10-2009 06:54 AM
mopar disc brakes 55Plaza Suspension - Brakes - Steering 2 04-26-2006 11:25 PM
mopar A body disc brake upgrade 74 swinger Introduce Yourself 2 12-04-2004 11:14 PM
Mopar 440 options 1meancuda Engine 4 02-02-2002 04:57 AM
