What New Intake Manifold to get - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2009, 08:30 AM
83SILVRADO's Avatar
GROUND POUNDER
I was looking at a new intake manifold for my silverado. just to get a little extra out of it. right now i have an edelbrock performer. with a holley 4 bbl 650 cfm carb. what should i get for more power. i was looking at a tunnel ram from edelbrock. but im not quite sure yet cuz id have to buy 2 new carbs too.
Old 02-27-2009, 09:31 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Uh... how about something we can use, like cam, compression, cubic inches, intended use...
A street engine never needs more than a performer RPM. Seriously. Especially with a 650 cfm carb. The intake has to match the powerband of the cam or you'll lose acceleration.
Old 02-27-2009, 09:55 AM
intakes don't make any power,,,it's just a pipe...
bigger simply increases the motor rpms operating range with more total plenum area and runners demensions....
if your cam is less than 5500rpms initial HP rpms peak,,,leave it alone...
a 4400lb truck needs all the low end TQ possible from higher Hg and velocity when accelerating from a stop sign...
my$.02:
even if the cam peak is 6,000rpms I would leave it alone if it is a daily driver...
a swap would make it maybe/possibly 1-2 tenths quicker max at the strip due to the 4400lbs
Old 02-27-2009, 12:04 PM
DoubleVision's Avatar
You`ve been swallowed by mores law: "If some is good more must be better"
Tunnel rams and dual quads are made for upper RPM horsepower and not very practical on street machines, not to mention the tuning headache 2 carbs cause. Many novice hot rodders make the same mistake when it comes to cams and intakes. Curtis said it right, the combo must be matched to make max power. You can`t count on one part to make the difference. In this case if you have a next to stock 350 that won`t see over 6000 RPM what do you need a tunnel ram for? it`s power band doesn`t start until 3500 RPM and goes up to 9000 RPM makes it lop sided for a street machine.
Old 02-28-2009, 09:02 AM
83SILVRADO's Avatar
GROUND POUNDER
you dont know what your talking about
my motor isnt "next to stock" *******. i just mentioned what i had as far as manifold and carb. you have no idea what parts i have on there. so get your **** straight
Old 02-28-2009, 09:07 AM
83SILVRADO's Avatar
GROUND POUNDER
weight
my$.02:
my truck weights 3800
Old 02-28-2009, 09:20 AM
i have the same question you have as far as intakes. have a RPM Edelbrock intake and thinking of putting on a tunnel ram single plane. 1967 c10 step side short bed. cam has band of 3000-6500.
Name:	1967 Truck 2.jpg
ID:	36604   Click image for larger version
Name:	1967 Truck.jpg
Old 02-28-2009, 09:26 AM
mine is a 350 with 10:1 and is not a daily driver tho
Old 02-28-2009, 09:38 AM
the sticker weight is not correct,,,
go to a concrete plant/dump/hiway trucks scale/whatever and get it weighed...
DoubleVision's post does say: "IF" your motor is nearly stock...
so you are the one that needs to get your sh## straight...
Old 02-28-2009, 09:43 AM
I would say yes, you should get the tunnel ram and 2 holley 750DP carbs... you'll love it!
Jordon
Old 02-28-2009, 11:14 AM
curtis73's Avatar
Wiki Edits: 16
Before you go being a complete anus, you still haven't provided us with ANY information that might help make the decision. How can we get it straight when you haven't told us anything? All you did was ask a vague question, got a cheerful and helpful answer, then swore at us cause we suck. Sit 'n' spin, jerkoff.
Cam
exhust
compression
head flow
intended use
converter stall
axle ratio
tire size
Old 02-28-2009, 11:18 AM
83SILVRADO's Avatar
GROUND POUNDER
his post says my motor is next to stock. hes an idiot
Old 02-28-2009, 11:19 AM
curtis73's Avatar
Wiki Edits: 16
Jordon
I think he should do a couple 1050s More is better after all.
Old 02-28-2009, 11:21 AM
83SILVRADO's Avatar
GROUND POUNDER
for curtis
ratio is 373
my tires are narrow as hell
its a daily driver
mild cam
not sure about compression
headers with glasspacks
im sorry if im appearing to be the dick in this but calling my motor next to stock as insulting to me.
Old 02-28-2009, 11:24 AM
curtis73's Avatar
Wiki Edits: 16
No, he said IF. Learn to read. You have no reason to lash out at a respected forum member, noob. His advice is spot-on, his repsonse was respectful and helpful, and until you tell us the specs of your truck, you are just continuing to be a complete spooge stain.
My guess is the truck doesn't even exist. You've posted several times about a magical 3800-lb truck (what, is it all aluminum?) but given us nothing but grief.
Grow up.
Altima GXE Intake Manifold Gasket awbazar Engine 5 01-24-2010 07:45 AM
Intake Manifold Gasket Installation - Help leejoy Engine 7 10-29-2007 07:19 PM
intake manifold is messed up, need help picking another 84Z Engine 1 08-21-2007 04:57 AM
Intake manifold volume techinspector1 Engine 8 07-13-2007 10:43 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
