what oil ( how long) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2005, 03:29 PM
What oil should i use in my camaro (in your opinion)
Im trying to get 500hp so i can run in the 11second zone then put nos.
How often should i change the oil, becouse it will never make it to 3000 miles.
Should i change it every 20 or 30 miles?
I curently use valvoline 30w or 15-40
I realize my motor isnt going to have a long life race cars never do but 15-40 is a good long life oil and 30w is old school as i have herd so do i go to castrol full sinthetic and realy thin (plus my oil presser is always to high)
I have herd good things about royal purple or a cheaper oil like castrol but in our hotrods most dont drive them if they are realy radical, so what about a hp chart for 300 hp 400hp &500 hp on up to 700 hp. oil intervals and such.
please tell me what you think
and thanks
Old 06-29-2005, 06:56 PM
Siggy_Freud's Avatar
Why do you think a 500hp motor is going to need oil changes every 30-40 miles? Id still do 3months/3000 miles on dino, and two to three times that distance/time for synthetic.
Most people around here use 5-30 or 10-30 for engines 100-600+hp. I say most, not all.
Can you explain a bit clearer your reasoning behind your thoughts?
Bringing history and technology together.
Old 06-29-2005, 09:34 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
oil change
I use 20-50 Penzoil or QS. I change my oil twice a season. If you use synthetic. You can make a whole season without changing the oil. Your motor will last for years unless you are using a high roller and tranny brake. Then it is advisable to refresh every 500 passes.
Old 07-01-2005, 04:28 PM
well guys i read some place that on a race car you would want to change the oil every 35 miles. well yes my engine will only see 100 or 200 miles in a year
but that is alot of oil to just throw away.
curently i cant even drive it with it in its current state.
So for a race car you recommend 5/30 or 10/30
What about when you brake in your new engine(cam lifters) what oil do you recomend.
I hear that back in the 70s everyone ran 30w oil (another magazine)
My camaro see's 7000 and 8000 every time it is taken out.
But just like the engine in it has 150 miles (mabe) and it lost compretion.
So what i say that block was junk anyway so lets build another(right)
and use a 350 BLOCK THIS TIME!
I think that this block is just too thin (besides that is what the machine shop said)
It over heats, it lost oil press, lost compretion and now it is already getting pretty worn
thanks yall, chris
Old 07-01-2005, 04:39 PM
GoneNova/406's Avatar
with that type of motor i wouldn't use anything but a performance synthetic.royal purple,mobil 1,valvoline,lucas,amsoil
Windage trays....... onebadmerc Engine 70 01-04-2005 07:57 AM
Oil smoke or....? 383 Chevy Finmike Engine 8 07-08-2004 06:25 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 06:17 AM
Low idle oil pressure chuckellison Engine 4 03-03-2003 08:20 AM
rebuilt engine no oil pressure in oil galley bmedina103 Engine 9 10-07-2002 11:37 PM
