What oil weight do you guys run? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-10-2013, 03:10 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
On a fresh break-in flat tappet,never,ever a detergent oil.Gibbs has a break-in oil and one after that for flat tappet cams.Oh I see where LSx rollers want the same kind of treatment.
  #17 (permalink)
Old 10-10-2013, 10:40 PM
Greg T's Avatar
www.krusinklassics.net
I've been running in flat tappet cams forever with plain old off the shelf 10W-30. Now that the ZDDP is gone I use VR1 10W-30. No additives, no crap, no non-detergent junk. Just good oil with plenty of zinc in it. I have never had a wiped lobe ever. If you assemble them properly and use good assembly lube you only need good oil with zinc.
  #18 (permalink)
Old 10-11-2013, 04:05 AM
75gmck25's Avatar
I have switched to using Mobil 1 15w50 because it has the high zinc and phosphorus levels that are recommended for a flat tappet cam, and its readily available from quite a few stores. I can usually find it on sale at Advance Auto or Autozone, often sold as a 5 quart bottle and filter combination. My truck has GM crate engine, so I don't know anything about machining tolerances. However, I have not had problems running the same weight of oil year round.
Bruce
OK GUYS! last chance for the sticker run before they go on ebay! chevyluvnpuppy Hotrodders' Lounge 10 06-30-2008 07:23 PM
What Oil do you guys run in a T5 manual Transmission x711 Transmission - Rearend 20 01-02-2007 12:26 PM
So..you guys going to run out and see Brokeback Mountain? tm454 Off-Topic 13 01-18-2006 04:32 PM
weight transfer for run joes350truck1 Engine 0 08-30-2002 05:52 PM
What weight oil do you guys use? dion Engine 16 08-06-2002 01:28 AM
