what other disc brakes to use on '68 charger - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2004, 10:13 PM
mitmaks's Avatar
Last journal entry: Grille
i know that a-body disc brakes work but heard that some fords do work too? which ones, i want most inexpensive one and easy to swap.
Old 05-10-2004, 10:20 PM
Pony's Avatar
?? What's wrong with what your using now? I had a 70 Charger and thought the disks worked fine. I don't know if the Chargers had smaller disk diameters for the small blocks as mine was a factory 440 x 4 speed. But if they do it would be easiest to go with the big block brakes.
Old 05-10-2004, 10:41 PM
mitmaks's Avatar
problem is mine are drums and drums suck, it takes while for them to stop very unsafe
Old 05-10-2004, 11:46 PM
Pony's Avatar
Now you got me wondering if my Charger had disks of drums??? It's been almost 20 years ago. Brain Fade!! I'd stick with the Mopar disks.If you put Fords on it, you'd have to call your car a FoPar!!
Old 05-11-2004, 05:38 AM
Wiki Edits: 49
Or worse..... a Mord!
The easiest way by far is to use MOPAR disks. Check these instructions on how to do this swap.
Centerline
