Nope....because the Trans=ams and Camaros have that torque bar thingy. The other rears don't have mounting holes for it.
Ontario Rodders |
81 was last year of the leaf spring GenII chassis. There is still no othr rear that will just bolt in except maybe an early GenI but that piece is about 2 inches narrower than your existing rear. You can get a posi and gear put in your housing for about 800-900.
Sorry...you said 81......I was thinking Gen 3.......82 and up.
Something out of a Nova should also fit your car...although most of them had those gears too......unless you get an older one....pre 73
Ontario Rodders |
what other rearend wold fit?
What could I bolt under an 1982 (big) jimmy with a 3.73, prefer pois. or limited slip or all wheel drive rearend. thanks
| Will a 79' Z28 8.5 rear end fit in a 68' Nova? | quick50stng | Transmission - Rearend | 1 | 03-19-2007 03:46 PM |
| rear ends | vin171 | Transmission - Rearend | 4 | 09-13-2004 07:25 PM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
| Chevy U-Joint doesn’t fit Pontiac rear end | 406chevelle | Transmission - Rearend | 6 | 07-05-2004 01:02 PM |
| Looking for Good Publications on Rear Ends | hot rod jerry | Transmission - Rearend | 4 | 07-29-2003 10:37 PM |
