what pads/discs to use w/ angle grinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2006, 09:10 AM
New Member
I'm getting an angle grinder (air powered) and don't know what type of discs to get for it? I plan on using it to prep metal (sand) clean welds, etc....I guess I'm asking what accesories I should also be getting w/my die grinder?
Old 01-11-2006, 08:48 PM
What Ever It Takes
Pad suggestion
For small jobs I use a Roloc set up. They have several sizes like 1" 2" 3" and have a good variety of pads to choose from. They have the buffing style pads that are color coded according to the roughness. They also have sanding discs that vary in grit like regular sanding materials. The part I like the most is that the pads and discs just spin in the base with a small twist and when they wear out you just spin one off and another on with no tools.
Old 01-12-2006, 04:04 PM
Cebby's Avatar
www.TOOLandFAB.com
Last journal entry: 1UZFE (Lexus V8) swap into 1993 4Runner
x2 on the Rolocs
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 07:58 AM
penion angle wolfemanbud Transmission - Rearend 2 10-04-2005 06:58 PM
notching tubing benchracer1 General Rodding Tech 16 04-12-2005 11:02 PM
Removing paint with a angle grinder prd Body - Exterior 8 07-28-2004 05:07 PM
