What part is this? T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2011, 03:22 PM
david-b's Avatar
Dave is THAT guy
Quick question and no luck with searching.
On the 350, on the passengerside, there is a plastic piece coming out of the trans. It's right below the oil cooler lines, and sits closer to the pan. The part going into the trans is a yellowish/orange (color blind ) and is held in by a 10mm bolt I believe. I broke this off.
What is it, and where can I find one asap? Thanks everyone!
Old 07-24-2011, 03:31 PM
SSedan64's Avatar
The piece below the Cooler lines would be the Detent/Passing gear cable. Connects to the Carb linkage. They're normally Black tho'.
Any Auto parts store should be able to get you one.
Old 07-24-2011, 03:35 PM
david-b's Avatar
Dave is THAT guy
Ok thanks. Just want to make sure since the color is different
In this pic, it's behind the bottom fitting, going in at an angle, right about where the dip stick is. Still the passing cable? Is this also known as the kickdown cable?
Old 07-24-2011, 04:32 PM
SSedan64's Avatar
Yes, Passing/Detent/Kickdown cable.
Old 07-24-2011, 04:44 PM
david-b's Avatar
Dave is THAT guy
Excellent. Thank you very much SSedan64
Old 07-24-2011, 04:49 PM
tv cable
that is what is known as throttle valve cable !! more commonly as kick down cable !! be carefull with adjustment because also helps control up shift working with vacum modulater routing is key cable must work freely !!
Old 07-24-2011, 04:53 PM
modulater
also loose all that rubber hose on vaccum modulater !! take the time to bend a piece of brake line and mount with as little rubber hose as possible!! modulater is picky on vaccum supply !! have run into probs with too much rubber hose !! will get you home but not good for permenant install!!
Old 07-24-2011, 04:59 PM
SSedan64's Avatar
The TH2004R & 700R4 use a TV/ThrottleValve cable, "The TV cable controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts." Adjustment is very critical.
TH350 uses a Detent cable, only controls passing gear or kickdown. Can be eliminated but, downshifts will be manual only.
Old 07-24-2011, 05:57 PM
No, no, and no. The TH350 does NOT use a throttle valve. A throttle valve changes line pressure in relation to throttle position. On the Powerglide, TH350, and TH400 the vacuum modulator performs this function. None of those transmissions use a throttle valve. On the TH350 the cable is a kickdown cable only.
Old 07-24-2011, 06:31 PM
sqzbox's Avatar
My pipes are my music
I've found that when putting a B&M shift kit in a TH350 (street strip mode) that leaving the cable disconnected provides a crisper 2-3 up-shift. Never cared much for full throttle auto down shift anyway.
Old 07-24-2011, 07:21 PM
joe p
your statement is only 2/3 corecct on 350/400.a powerglide does not get any shift timing from the modulator it controls line pressure only.shift points are from throttle linkage similiar to a chrysler 727.you can plug the modulator and it will still shift at same speed
68 GTO, what is this part? Part of the idle control for the carb?? adam83 Engine 2 10-19-2012 05:58 PM
T-350 Part I.D. 91CamaroDude Transmission - Rearend 2 10-04-2012 02:27 PM
350 buick;tough starts, sputters at part throttle malibusimon Engine 5 03-20-2012 11:36 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
i need a piston ring part number. 98 350 vortec 406 ss monte Engine 3 06-03-2006 10:22 PM
