What is the payload capacity for a front i beam axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2010, 05:27 PM
I was kicking around using a cummins 6bt in my project on the boards, but I want to run a I beam style front end like one of the ones speedway sells. How would one of these do with a 1000lb motor resting on it?
Old 10-23-2010, 08:53 PM
It might ... but I would be leery. If you want a I beam ... find a Henry Ford one. They are forged ...
They installed them under 1/2 ton and 3/4 ton pickups.
That Cummins is HEAVY
Old 10-23-2010, 08:57 PM
what about the tube style are they any better?
Old 10-24-2010, 10:24 AM
The tube type are welded ... and IMHO not as strong
Old 10-24-2010, 11:05 AM
Wiki Edits: 31
the tube axles are listed with a 2,500 lbs weight limit for the entire car as per Speedways listing.. that's pretty much a T bucket with a full interior, tall windshield and a 350/350 engine/ trans combo
I would go with an original, or a good aftermarket I beam..
Front axle on my 1947.1 chevy panel truck RATS NEST Hotrodding Basics 7 02-20-2008 10:23 PM
Dropped front axle questions. WillysWagon Suspension - Brakes - Steering 2 01-18-2008 06:51 AM
48 ford truck w/T model front axle tripp68 Suspension - Brakes - Steering 13 01-02-2008 06:36 PM
gasser front axle failura Suspension - Brakes - Steering 3 10-17-2002 05:32 AM
1938 chev - straight axle front end WILLARD(SONNY)STOTLER Suspension - Brakes - Steering 4 12-30-2001 03:26 PM
