I`d suggest the KB pistons that have a 12cc D - Dish, this keeps Quench active, and you`ll gain a slight compression ratio increase. If the pistons you have are the full dish or concave type, there is no Quench, and Quench is important to resist detonation and it helps with throttle response. a flat top from Sealed Power with coated skirts would likely suffice also since your running a cam that bleeds off some cylinder pressure. there all over Ebay at a good price. stay clear of the flat top pistons that are cheap, under 100, these have .020 cut off the tops. after you get the pistons you want, check how far they are in the bore and set your Quench distance, don`t go under .040 and don`t go over .060. even with the D dish pistons, a good Quench will help power.
I have run a very similar setup in several of my vehicles, you can improve the idle response just by drilling 1/16" holes in the backside of the primary butterflies of the carb. This will also improve your vac. readings. I use this particular cam and engine setup because it has a great idle sound and broad torque and hp. curve. I usually use a Holley 750 vac secondary carb.
Ditto with DV and Bob, I have run the same pistons and set-ups.
You can get different types of dished pistons/ head gaskets for compression. On flat tops just make sure they have the valve relief size's to the valve size and lift your using.
Luv the smell of NITRO in the morning. |
