Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what plastic should I use
  #16 (permalink)
Old 11-07-2002, 03:40 AM
tlambert's Avatar
tlambert tlambert is offline
If its the type with just a round hole (70s ford style?) with no reinforcement what you did should be fine. Flangeing it was a good idea so it will add more strength and after the weld has been ground you won't end up with a weak area around the weld joint.
Oh yeh those directions do come in handy don't they.
