what plastic should I use - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 07:03 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Red face what plastic should I use
So, I have the gutters shaved, ground, welded, ground again. Now am I ready for plastic filler? what I have available in town are: Dynatron Dynaglass, Dynalite by bondo, or Autobody Master #4404. all are 2 part fillers and like I said here in town. Has any one used any of these? Do I need to drive 40 miles to town. what do you think. oh yeah, how fer back should I feather the filler from the SMOOTHNESS <img src="graemlins/pimp.gif" border="0" alt="[pimp]" /> <img src="graemlins/drunk.gif" border="0" alt="[drunk]" /> <img src="graemlins/pimp.gif" border="0" alt="[pimp]" /> <img src="graemlins/drunk.gif" border="0" alt="[drunk]" /> <img src="graemlins/nono.gif" border="0" alt="[nono]" />
Old 11-05-2002, 07:14 PM
Question
Hey Halloween King, what do you use?
Old 11-05-2002, 07:23 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
I myself use Evercoat brand filler, from thier lightweight plastic to fiberglass or even the ocasional metal 2 metal. Somtimes I use filler by 3M, but its not reddily available around here. I myself try to stay away from anything made by Bondo, but thats just me. I like Evercoat its a good filler and its redily available here and not to terribly exspensive.
HK
Old 11-05-2002, 07:29 PM
Thumbs up
Garcia
Old 11-05-2002, 07:42 PM
Post
He's dead havn't ya heard :p
HK
Old 11-05-2002, 07:44 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Wadd'ya think of mar-glass, other than it being a beetch to sand?
Old 11-05-2002, 07:58 PM
Post
course he's DEAD, only gone home. should I use a fiberglass filler or stick with plastic. area to be done is'nt to deformed. also, what is better for larger surfaces, say for instance, a gas filler hole. sheetmetaled in, ground as smooth as I ccan get, just to make it purty
Post
Its not a bad product at all, just a real beetch to work with like you said, if you think thats a real beetch to sand try metal2metal after its cured you need a frikin arm of steel to do it (why I rarely use it). Try Evercoats 'glass filler, its easier to work with. I try to use as little filler as posible unless its one of those cheap rush for fun jobs lust to make your day-to-dayer look good without alot of work.
HK
Old 11-05-2002, 08:00 PM
Post
its my daily (gonna be) driver, though I don't wanna 1/2 arse it
Old 11-05-2002, 08:02 PM
Post
I use 'glass filler for big jobs that I want to stay for awhile with structural integrity, then use a thin coat of plastic filler to smooth out the 'glass, because everyone knows plastic smooths way better than 'glass filler. Just for small jobs for filling in or smoothing just use plastic, no need to use 'glass. I only use glass when I'm doing a $600+ cost in materials type job.
HK
Old 11-05-2002, 08:04 PM
Post
I 'ppreciate it, will keep you posted. <img src="graemlins/crash.gif" border="0" alt="[crash]" /> <img src="graemlins/drunk.gif" border="0" alt="[drunk]" /> :p
Old 11-05-2002, 08:12 PM
Post
Happy to help
HK
Old 11-06-2002, 02:23 PM
tlambert's Avatar
Post
Crazy L you spoke of filling a gas hole in, I've seen this done by welding a piece of sheetmetal in place(door handles) without cutting the surrounding area out. Each time I've seen this done they show up later in the paint job. The best way to fill an area like a gas opening or door handle is to cut the area out and weld another piece into its place. When this was done it didn't show. FYI
Old 11-06-2002, 02:34 PM
tlambert's Avatar
Post
Crazy L, by the way we use Evercoat brand fillers and polyester fillers for my class, they dry good and sand pretty easy. Sanding with 40-80 grit is not bad at all. Don't forget to read the directions on the label <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> it does seem to help with questions that may arise during use.
Old 11-06-2002, 07:51 PM
Post
so let me get this clear..... I should cut a section around the filler neck (incab tank relocated to under bed) and weld in a patch? what i did was cut a circle close to fit, and flanged it to fit somewhat flush from the inside of the cab, not to much of a gap, was hoping filler would take care of it but i dont want to be in the middle of my paint job and see the patch....... please expound on this.......
of yeah,,,,,when all else fails, read the directions <img src="graemlins/crash.gif" border="0" alt="[crash]" />
