.035" get the job done fine for a performance application. .040" is good. .060 is way too much.
If when you set the plug gap at .035" and the ground strap goes past the center electrode you can trim the ground strap length as required.
Trim the ground strap so it is just short of the far edge of the center post.
File smooth any sharp edges of the ground strap end after trimming.
