What is a posi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2002, 04:11 PM
Question What is a posi?
hey I am a new member with lots of questions. my first will be, How do I identify a posi rear. I did the wheel spinning technique and mine passed. but when I "get wheels" the passenger side is the only one that grabs.
Thanks dmorris1200, I didn't know the proper technique. your info is greatly appreciated.
[ November 09, 2002: Message edited by: Sheir-Ron ]</p>
Old 11-09-2002, 04:16 PM
dmorris1200's Avatar
doesn't play well with others
Post
You say you did the wheel spinning technique. Are you sure you know the technique? Car jacked up and in neutral, spin one tire, if other spins in the same direction 'posi', if it spins in the opposite direction or not at all 'open' rear.
Part 2- If both tires spin together have someone hold one tire while you try and spin the other. If it offers little resistance and spins while the other tire is being held your posi clutches are shot.
BUILT FORD TOUGH
