what pressure cap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2007, 09:53 AM
what pressure cap?
HI
Im running a modified Nissan 4 cyl with 180 thermostat and 7 lb pressure cap. everytime I shut it off a little bit of coolant comes out the overflow (no catch can yet) I was going to change to a 14lb cap but a guy told me I shouldn't because the aluminum head will warp .the engine is a 1979 just had a valve job&head all checked out and just had the radiator all gone over(it had a small leak),what thermostat and pressure cap should I be running? Catch can is on list of things to do
Old 02-23-2007, 10:20 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I'd have the parts store test new caps with their tester until they found one that actually tested 15 and then I'd put it on.
Pressure cannot warp a head, overheating does.
Old 02-23-2007, 10:38 AM
nitro_baller4692's Avatar
floppers forever
pressure raises the boiling point of water
i've never asked a parts store to open a package to test a new cap,they would probably tell me to go blow myself.but thats illinois for ya,not all that friendly like they are in some southern states.
Old 02-23-2007, 03:15 PM
I don't think yhe parts stores around here would do that either. I'll probably buy a name brand one and have faith in the factory.Anyone suggest which brands are the most reputible?
Old 02-23-2007, 03:29 PM
poncho62's Avatar
Wiki Edits: 5
You need to look at a manual and see what pressure your Nissan system calls for...........It's probably a closed system with a puke tank, that has a lower pressure cap.........7# sounds about right.
Old 02-23-2007, 04:52 PM
This engine is not stock would that make a difference?
Old 02-23-2007, 04:55 PM
Wiki Edits: 31
stock preassure is 10-16 # for anything made after 1980
Old 02-23-2007, 05:00 PM
my engine is a 79 200sx nissan,bored,bigger valves ,high lift cam ,header and 390cfm holley
Old 02-23-2007, 05:56 PM
xntrik's Avatar
I have seen most of the major brands, Murray, Stant, etc. and 80% of them will not test very high.
The last one I bought at O'Reilly's, Murray brand, the store tested 5 to get one that tested 15. One tested almost 0, one 3 psi, two were around 11, finally the last one they had in stock tested 15.
The last Stant I bought the best I could test was 14 with the store's tester.
Old 02-23-2007, 06:05 PM
Well I can ask if they test them,but I still don't know for sure what pressure I should be using
Old 02-24-2007, 02:19 AM
Check the shop manual, buy a cap rated at the same pressure datsun used (no your mods don't really change the required pressure). Keep the receipt, take the cap to your friendly neighbourhood radiator shop and ask them to test it. If it fails, then take it back, get another and take it, along with a 6 pack to the radiator shop. Keep trying 'till you get the right one.
Those old l20 datsuns would crack heads if over heated and corrode with hard water, but if the stock system was kept in good order with approved coolant, the correct thermostat and cap, they cooled just fine.
Old 02-24-2007, 06:38 AM
sounds reasonable,thanks
Gary
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 04:36 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
Fuel Pressure DoubleVision Engine 18 05-31-2003 05:49 AM
