What primer do I use
My 57 ford has been with me for a long time and am now ready to start finishing it, I have done bodywork over the years with different primers over it , what kind of aprimer should I cover all this with ??
If it where me I would sand the whole car real good if the intent is to give it a complete paint and prime it with a couple good coats of spi epoxy.
IF YOU TAKE YOUR PRIMER DOWN AS BEST YOU CAN WITH BLOCK SANDING THE FACT THAT ITS OLD PRIMER SHOULD NOT BE A ISSUE. You'll get people that wil say it all has to come off don't buy it. Yes it's not as good as what you can buy today but for years we used it because that's all we had. Every custom paint job in the country was done with it and some looked pretty good to. I did ton's of jobs back in the day with lacquer primer and had lots go 5-10 yrs . How long will you own the car or in 10 years will you want it a different color anyway. If that's the case the primer on a car that only gets used a few month out of the year isn't that big of a deal.Just seal it with epoxy and let her fly.
| Epoxy Primer, Urethane Primer Compatibility | brimcp99 | Body - Exterior | 7 | 11-22-2010 07:04 PM |
| Etch Primer SUCKS? Use epoxy primer? | Arizona El Camino | Body - Exterior | 14 | 10-22-2009 08:51 AM |
| Epoxy Sealer-Primer With 2K Build Primer on top | kilgorq | Body - Exterior | 4 | 04-29-2008 04:30 PM |
| can i spray epoxy primer over etching primer without sanding? | wickiewicked240z | Body - Exterior | 1 | 08-29-2006 09:07 PM |
| Do you need etching primer under featherfill primer? | Fordy8man | Body - Exterior | 14 | 10-29-2003 07:23 PM |
