What primer / sealer to use under base coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2012, 06:01 PM
Jimbo17's Avatar
Nostalgic Racing Decals
I am wondering what primer / sealer to use before I apply a base coat / clear coat.
Should I just use whatever the rep tells me to use for the brand of paint I will be using?
I have been to two different automotive paint wholesalers and they were not to helpful so far.
I have even thought of just ordering from Eastwood and trying their products.
One rep told me to use Montana products and the other one said to use Matrix products.
The problem I am having to that the guy who shot my truck four years ago is now serving about 20 years in jail for something he did and I think he used Matrix paint but I am really not sure. He did a nice job.
Another question is what size compressor should I use with an HVLP gun since I am not painting the entire truck but just the rood area.
Thanks for your advice and help. Jimbo
Old 07-04-2012, 06:42 PM
mitmaks's Avatar
Last journal entry: Grille
You should use epoxy primer/sealer. SPI is a good sealer and when reduced up to 50% with appropriate reducer it will lay out smooth. You only need one coat before spraying base/clear. Make sure you give a nice wet coat.
Old 07-04-2012, 07:21 PM
gto_ron's Avatar
sealer
mitmaks is right on the money. I always seal my 2k with wet coat of epoxy primer. I use to use DP40 until I tried SPI. I'm not knocking the PPG primer but SPI flows out better and costs less.
regards
Ron
Old 07-04-2012, 08:25 PM
mitmaks's Avatar
On EDP panels (black primer on aftermarket panels) I scotch brite/320 scratches and shoot 2 coats of SPI and then wetsand it and shoot another coat to seal it and it's ready for paint.
Old 07-05-2012, 06:37 AM
deadbodyman's Avatar
Wiki Edits: 11
If your just shooting over existing paint theres no need for a sealer.just sand with 320 and shoot it...if you have some primer spots just shoot the spots once or twice (with paint) to get everything the same color before you start shooting the rest...but epoxy IS the best sealer to use if you choose to seal it....
Afraid to color sand my new base coat / clear coat. Can I go straight to fine cut? Zeeb Body - Exterior 12 06-12-2012 09:36 PM
spot repair of metallic black base coat clear coat on bumper bar pinkotoo Body - Exterior 0 02-25-2012 04:35 PM
wet sanding before sealer/base coat xpsyclonex2002 Body - Exterior 6 04-27-2011 05:47 AM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 04:59 AM
