What primer should I use for my vinyl job? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2012, 11:41 AM
_X_ _X_ is offline
Hello
A while back I started sanding my car down to bare metal. I planned on sanding everything down and following up with some etch primer, filler, 2k primer, base coat, etc....
Kinda have a change of plans now. I will be wrapping the entire care with 3m carbon fiber vinyl. So with that I don't know what to do as far as paint.
I'm sure it's not a good idea to put the vinyl over bare metal, but I don't know if
I should be using epoxy primer and 2k primer to prep the surface for wrapping when I can possibly go with some less expensive.
Would it be okay to use some body filler and cover the body up with some premixed duplicolor primer from autozone?
Essentially I need to prep a bare metal surface for vinyl wrapping.
Not really looking to spend a ton of money on primer paints but at the same time I don't want to do a half a$$ed job.
Any help would be greatly appreciated.
I will be doing the vinyl job on a Datsun 280z by the way
Old 10-04-2012, 12:58 PM
Do your body filler and then use a Good quality epoxy primer and you should be fine. Rattle can does not produce enough film build.
primer paint job ponchopower48 Body - Exterior 12 11-08-2010 10:41 AM
Vinyl Interior and Vinyl Top? Coodeville Interior 1 08-31-2010 03:03 PM
primer job impalalover60 Body - Exterior 4 09-14-2008 07:41 AM
Vinyl Wash Primer 68C10 Body - Exterior 13 06-05-2007 10:26 PM
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 10:31 PM
