What Products Do You Like Best??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2012, 11:48 AM
I just want to know everyone's opinions on the products that they believe are the best and why they feel that way about the products.
This includes:
Primers
Sealers
Paint/ Base Coat
Clear Coat
Putty
Polishing Stuff
Other Great Products?
Old 02-05-2012, 12:06 PM
mitmaks's Avatar
Last journal entry: Grille
USC polyester glazing putty
Evercoat body fillers
Meguiar's compounds/waxes
PPG Deltron base
SPI epoxy
Old 02-05-2012, 12:10 PM
TucsonJay's Avatar
Once I use a product, and it fails... I stop using it forever.
Here is what I use, with consistant results, despite varying conditions.
PRIMER Marhyde Ultimate Primer (2K urethane)
SEALER Sherwin Williams Sur-lac... (red, gray, or tintable)
PAINT/BASE COATS R-M, House of Kolor, and X-Otic Colours (Use as needed)
CLEARCOAT R-M Diamont DC92
PUTTY Fiberglass Evercoat Euroglaze
POLISHING: Sand with 1200 Meguiars, 3-M 6031 comp. with white waffle pad,
...then 3-M 05973 comp with gray waffle pad.
OTHER Grow Products reducers,
3M green paper masking tape,
Dupont 222S clear adhesion promoter.
Of course sandpaper grits and drying times play a key role too.
This system has worked for me for 10-12 years without fail. I occasionally use other systems at customer's request.... but none ever give me the consistant "workability"... flexibility... and quality that this has.
Old 02-05-2012, 12:16 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
spi epoxy
ppg concept ss for color
prospray base when forced to use base
spi clears
the chemicals guys compounds
i use no primers or sealers.
Old 02-05-2012, 12:36 PM
So you use Dupont 222S before your sealer? Why is that? Do you use it for flow coating too?
Old 02-05-2012, 01:22 PM
Holy crap did you get that 222S from a sunken ship or or with a time machine or something, I didn't even know it was still available!
From what I remember it is simply lacquer clear and a very slow thinner. At least from what I remember, that is what it was. Not something I would use today.
Old 02-05-2012, 01:34 PM
TucsonJay's Avatar
I don't use it on every job... just when adhesion may be questionable.
An example was when a bike customer had a bunch of his metal engine parts copper plated, and then polished. I knew if they were left exposed they would turn brownish and eventually have a blue oxide show up.
I also could not sand them, as it would ruin the polished surfaces.
I told him what I had in mind, and that I could not guarantee that it would stick well to a polished surface that gets hot.
The only other option was to drive 250 miles twice, to have them clear anodized by an anodizing business that offered "micro polishing/chemical polishing".
I used the 222S, then two coats of catalyzed clear. That was about 10-12 years ago. They still look good.
Old 02-05-2012, 01:46 PM
TucsonJay's Avatar
I'm not a chemist. It may be lacquer based... but it's a slightly yellowish mix... and damn sure doesn't smell like lacquer!!! That stuff will choke you to death! :-( It might even be "yak p!$$" for all I know....but it sticks to a questionable surface better than anything else I've used in the last 47 years!
I am about to use it to complete a half-finished a job that has set for 2-3 years... and cannot be sanded without ruining a bunch of airbrush work.
I usually only have a need for it every 3-4 years. Not on normal jobs.
Old 02-05-2012, 02:45 PM
222s is a adhesion promoter ready to spray outta the can made by Dupont. we used it all the time back when we used Dupont.
i use Pro-spray base everyday in my shop
i use everything else SPI(primers,sealers,epoxy,w-g remover,reducers clears)
i have had better luck and success with these Products over any of the others i have ever used.
Travis
Old 02-05-2012, 02:51 PM
I can't figure out how to get some SPI products. Does anyone know where they're sold in Ontario/ Toronto? Or if I can get it online for a decent price in Canada?
Old 02-05-2012, 06:30 PM
Old Fool's Avatar
This includes:
Primers
Sealers
Paint/ Base Coat
Clear Coat
Putty
Polishing Stuff
SPI primers
Pro-Spray or Concept
SPI clears
SPI w&g remover
Dolphin Glaze
Marson Platinum
3M Compounds
Old 02-06-2012, 02:54 PM
It seems like everyone uses SPI products here. I made this thread in other forums and no one said anything about SPI products.
I think their clears aren't supposed to be good for down draft air booths. I don't really know.
PPG products exodus1500 Body - Exterior 21 05-18-2010 07:39 PM
u-pol products. panelwagon62 Body - Exterior 5 04-12-2010 08:46 PM
Where Can I get SPI products??? SouthernRodder Body - Exterior 2 09-04-2006 12:23 AM
U-POL products dwhitt Body - Exterior 3 07-08-2006 06:57 AM
3m Products vman53 Body - Exterior 0 09-08-2003 06:34 PM
