at what PSI, in my 75/25 mixed gas bottle, can I consider it empty?
my mixed gas bottle (75/25) for my mig is down to 400psi
when can I consider it empty? how low will it go and still be effective? I dont want to give away a bunch of gas on my bottle exchange but i dont want to run out either I only have one bottle also has anyone used different ratios? |
no idea as far as the psi.. but you could call and find out what the bottle weight is empty..
scale yours and thats the pounds left.. if they can't tell you.. then weight it when it is empty. and use that as a guide, psi can change with temp.. good luck |
its a small bottle, and its going fast, just watched it drop another 100psi
so off to the airgas store we go (its 25 miles away)
I run mine until I can't hear any hiss when I pull the trigger - or when the weld sound starts to snap and pop. I also just bought a new adjustable regulator instead of a fixed and so far am down to about 15cfh with good welds.
my biggest concern was running out over the weekend
i talked to the guys at airgas about the 84/16 steelmix they said it would make my life easier on the thin stuff so thats what I got did I screw up? anyone else use it? I remember it was mentioned by someone in a thread a while back |
Is it still a two part ar/co2 ? should be fine. The 'regular' stuff is 75/25. also sold is some ar/helium but I believe it is for stainless. also some ar/ox in different ratios and some three part ar/he/ox for stainless.
Go with what you guy is telling you and see if it works for you and your conditions. Different things for different folks or something like that. |
| Recent Garage - Tools posts with photos |
| Empty MC, new bench bleeding? | staleg | Suspension - Brakes - Steering | 2 | 06-02-2011 11:34 AM |
| empty trailer from fla to nebraska | 59 wagon man | Hotrodders' Lounge | 0 | 06-28-2007 08:59 PM |
| trans. empty during break in | runn141 | Transmission - Rearend | 12 | 05-12-2007 08:09 AM |
| Empty | Ken-96GMC K1500 SC | Transmission - Rearend | 0 | 05-31-2003 09:55 PM |
| empty | IHAVECHEVYPARTS | Electrical | 3 | 11-19-2002 06:05 AM |
