what to put on floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2010, 05:54 PM
what does everyone use on their floors and firewall(inside).
rocker guard or what?
and do you primer first..
Old 01-25-2010, 06:44 PM
Depending on the look you are after, underseal on the underside and paint on the top side. If you are going show stuff, then paint on the bottom side too, but I assume you would know that.
But YES epoxy primer first on both top and bottom.
Old 01-25-2010, 09:58 PM
Rag top bird's Avatar
Hot rods are still the king
I sandblast the bottom side and the firewall at the same time and prime with epoxy and paint with GM reconditioned black
Floor Pan Refinishing (LONG) Psquare75 Body - Exterior 1 05-29-2007 09:47 AM
Need help straightening van floor lon77 Body - Exterior 17 01-17-2007 06:32 PM
Interesting approach at channeling an early Ford. MARTINSR Body - Exterior 5 12-12-2006 10:44 AM
floor fabrication johnnymopar Body - Exterior 2 03-13-2006 07:00 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 06:56 PM
