what rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2003, 06:45 PM
New Member
Post what rear end?
what rear ends will built up with no problems to my 91 s-10, 4.3l v-6 with a 5 speed manaul
Old 03-12-2003, 07:25 PM
Post
could be wrong but a rearend out of a 78 to 80 model malibu will bolt right up, and you could put just about any gear in it. nephew has a 78 malibu and the only rearend that would fit was out of a s-10, and has put a 373 in it and running 8.63 in an 8th track
Old 03-13-2003, 04:23 PM
Post
The Malibu rear mentioned will not bolt up to the S-10 leaf springs. The malibu will have brackets for the upper and lower control arms as well as for the coil springs. The length may be correct but there will be some cutting and welding before this rear bolts into the S-10.
Old 03-13-2003, 05:15 PM
New Member
Post
will blazer, jimmy and or an astro van rear end work?
