What Rear End do I Have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2003, 07:09 PM
hiimed's Avatar
Truck - '49...Driver - '47
Arrow What Rear End do I Have?
I'm building a '49 Chevy pick-up with a 350 engine and a TH 350 trans. The rear end is not the original one but I don't know what it is. It has 10 bolts and the ID is 3894859NF. Any help would be greatly appreciated.
Thanks
Ed
Old 01-25-2003, 04:39 AM
5.0Towncar's Avatar
Post
Here you go.
Camaro Differential Code # 1967-1969
10-bolt
Casting Number 3894859NF
Bolt Diameter 3/8
Ring Gear Diameter 8.20
Pinion Diameter 1.483
Axle Splines 28
Shaft Length 29 33/64
Old 01-25-2003, 03:29 PM
hiimed's Avatar
Smile
5.0 Towncar-
Thanks for the info. We got the truck running today. It has set for about 7 years. The Q-jet just didn't want to co-operate and finally caught fire. I think I'll replace it with a Holley 600. I think I'll keep the rear end and just change the suspension.
Again, Thanks for the Help
Ed
Old 01-26-2003, 04:44 AM
5.0Towncar's Avatar
Post
No problem. Have fun with your ride. Steve
