What rear end does my 1984 Z28 have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2002, 07:16 PM
Rubberman2003's Avatar
Post What rear end does my 1984 Z28 have?
It had the 5.0 HO before i put my 350 in it..i think its 3.42 or 3.73...Thanks
Old 10-06-2002, 03:03 AM
aka Duke of URL
Arrow
On the right axle tube, facing towards the front of the car, will be stamped a series of code numbers. You may have to clean the tube to read it as a result of GM's anti-rust policy... ...of trying to cover metal with blow-by.
Give the first three characters and I will try and cross it over for you. Remember, this will only give you the assembly ratio. Someone may have changed it at a later date.
Old 10-06-2002, 02:55 PM
Post
Ok i will try and do that, it is rusty your right, i do know that it hasnt been changed so ill have to look when i get off work, thanks
