What rear end gears would you use. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2011, 05:46 PM
oldtimercarnut's Avatar
Ok I just wanted some input on what rear end gears to use. I have a 1967 camaro 468 big block med. cam. It is attached to a muncie M-22 and my rear wheels are 275-60-15 The gears I have in it now are 5.14 posi. We all know that is to high for the road. I drive mostly around town and Once or twice a year I take a trip about 250 miles away. I am thinking about maybe 3.55 gears. Can I change just the ring and pinion if going with 3.55 or will I have to stay with 4.11 or lower with the 5.14 set up. Would like to know your thoughts on what gears you would go with. Thanks
Old 07-27-2011, 06:34 PM
sqzbox's Avatar
My pipes are my music
Tell ya right now, you ain't going to like the switch to 3:55 from 5:14. Better go with 4:10's at least. What rear? 12 bolt?
Old 07-27-2011, 06:55 PM
yes it is a 12 bolt. The 5.14 gears are in the car from when it ran at the strip. I tried them on the road and I am at 3000 rpm at 45 mph. I was hoping that if I used 4.11 I could get away with just changing the ring and pinion.
Old 07-27-2011, 07:21 PM
gears
3.55 3.73 You own a gas station?
Old 07-27-2011, 07:24 PM
No gas station. When you put it that way the 3.73 sound good
Old 07-27-2011, 07:30 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
4.30s & Gear Venders Or 4.30s & 200-4-R
Rich
Old 07-27-2011, 07:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as I recall GM had a 3.31 gear for early Camaros. My 69 Camaro with a mild 454 and 3.31 gear. it would drive any where and run 12.9 at Firebird track here in Aridzona... back in the mid 1980's
Old 07-27-2011, 08:23 PM
sqzbox's Avatar
You just told where you live now! You must be buds with Techinspector1.
Old 07-27-2011, 08:25 PM
sqzbox's Avatar
Let's try this. What rpm do you want to run at 60 mph?
Old 07-27-2011, 08:35 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I like the 3.73 gears i have in my camaro. JMO I am running automatic at the moment with 3000 stall and 26 inch rear tires.
Cole
Old 07-27-2011, 08:42 PM
I would like to run around 2500 rpm at 60 mph. Cole what is your rpm with the 3.73 on the highway?
Old 07-28-2011, 04:11 AM
SSedan64's Avatar
Good calculator for rpm & speed>> http://www.f-body.org/gears/
Trans Ratios etc..for Calc input>> http://www.maliburacing.com/auto_tranny_id.htm
Old 07-28-2011, 05:34 AM
Thanks that thread really help. I also used a couple other threads and for what I am using the car for I think 3.73 will be the gear of choice. So will the Differential have to be changed because of the smaller ring?
Old 07-28-2011, 05:48 AM
SSedan64's Avatar
The only 3-series gear available for a 4-Series Carrier is the 3.73 ratio, so you can use the same Diff Carrier. For any other 3-Ser. gear you will have to change the Carrier.
Old 07-28-2011, 06:12 AM
That is great information!! I will look for one and order it as soon as I take the differential out. Would Summit carry 3-series gear for 4-series Carrier ?
********** rear gears hrm Transmission - Rearend 2 05-21-2011 08:56 PM
which rear end gears to run? diamond mike Transmission - Rearend 25 03-05-2010 10:09 AM
Hot rod rear end gears 47chevrolet Transmission - Rearend 36 01-21-2007 04:52 PM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 10:17 AM
rear end gears RHipps Transmission - Rearend 2 01-11-2003 11:29 PM
