what rear end to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2006, 01:10 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
I was discussing the fact that I will have to change the torque tube that I now have in my '48 Chevy Fleetline with a man that I had just met. I told him about the 250ci engine and TH350 tranny swap that I am planing. He said that if it was him he would put a rear end from a v8 stick shift. Question: Is this sound advice? I am confused now, I did not think it made much difference. He mentioned something about more torque that the six could muster out of that type of rear end. I think he is full of bull.
Al ??????
Old 02-11-2006, 03:13 PM
Not really full of BULL .......a V8 stick shift rear end ratio is, as a general rule , a 3.50 to a 4.10 ratio. These ratios, combined with the 2.52 ratio of the first gear in the Turbo 350, would make the truck take off from a stop with less strain and also would be a " better " pulling gear. Trucks from the past ....were almost always geared like that for working.....
IF........you are keeping the front suspension stock, I would find a rear with the same wheel pattern......and a ratio of 3.5 or so......with the proper width.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
