What is the rear end width of a 81' Chevy Half ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2003, 05:13 PM
Post What is the rear end width of a 81' Chevy Half ton
I have access to 2 free 81' Chevy half ton rear ends. If I want to go pick them up they are mine. If they are too wide I don't want them.
Thanks,
-Billybob
Old 03-30-2003, 05:57 PM
woodz428's Avatar
Troll Hunter
Arrow
What are you wanting to put them under? That will be the determining factor, if it's an early rod they are probably too wide. I'll see if I can't get the dimensions though.
Old 04-02-2003, 04:29 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Post
Mine here measures at the outer drum to wheel mating surface 64-1/2 inches.
Hope that helps.
