What rearend is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2012, 08:27 AM
rollenhard's Avatar
I cant figure out what gm rearend this is its a 10 bolt
These are the numbers stamped on the axel tube
BWH C262 2
Thanks
ID:	69167   Click image for larger version
Old 11-16-2012, 09:18 AM
big gear head's Avatar
High Performance Rear Ends
7.5 GM 10 bolt. Probably from a S10. You didn't show pictures of any brackets or mounts, so I can't say for sure.
Old 11-16-2012, 09:51 AM
rollenhard's Avatar
Thanks big gear head
here are a couple pics of the rearend
ID:	69176   Click image for larger version
Old 11-16-2012, 10:55 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
7.5, the 8.5 has square ears near the bottom, the 8.2 has a different cover.
K
Old 11-16-2012, 11:06 AM
rollenhard's Avatar
so what your saying killerformula its a 7.5 Chevy S10?
Old 11-16-2012, 03:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unless I'm mistaken it looks like the original spring perches were removed and what is on there now was welded on.
The stamped in code from the axle tube (BWH) should tell you what the ratio was originally and if it was limited slip or not- but I do not know a source for the codes for the 7.5"/7.625" diffs... so if anyone has these codes, I'd appreciate a link to them.
The easiest way to determine the ratio is going to be pulling the cover and counting teeth or look for the stamped-in numbers on the edge of the ring gear. It will look something like 10 40 (4.10:1), etc.
Old 11-16-2012, 03:22 PM
Yea, that's a S10 7.5 rear end. Those are S10 spring perches. It's an early version because it has the older type housing end with the large bolt at the top and 2 small botls at the bottom. The later S10 rear ends had the 4 bolt housing ends.
Old 11-16-2012, 03:23 PM
rollenhard's Avatar
Thanks cobalt327 for the input
Old 11-16-2012, 03:29 PM
rollenhard's Avatar
Any idea of year?
Old 11-16-2012, 03:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The code C262- if a date code like it appears to be- would be March 26 of a year ending in 2. '82, '92, etc. I don't know enough of the specifics of S-10 rearends to help more than that. Did you see big gear head's post right before yours, above?
Old 11-16-2012, 03:51 PM
rollenhard's Avatar
sounds good gives me some idea of what it is
Thanks
Old 11-16-2012, 04:59 PM
By '92 they had already gone to the 4 bolt backing plates on the brakes. This one is earlier than that.
Old 11-16-2012, 05:29 PM
rollenhard's Avatar
Thats good to no on the 4 bolt backing plates
Old 11-16-2012, 08:23 PM
evolvo's Avatar
Heathen
Not to be nit picky, but a 10 tooth pinion and a 40 tooth ring is not a 4.10:1. It's a 4.0:1. A 10 tooth pinion and a 41 tooth ring = 4.10:1.
Old 11-17-2012, 05:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Aah, thanks. Good to know there are guys like you keeping me honest.
rearend flathead v8 Suspension - Brakes - Steering 1 11-03-2008 10:07 PM
what is my rearend? Magikal Transmission - Rearend 10 04-04-2006 02:09 AM
which rearend? cameano Transmission - Rearend 5 02-02-2006 06:34 PM
rearend help 39 OLDROD General Rodding Tech 10 01-17-2006 07:07 PM
rearend ottis Transmission - Rearend 1 12-06-2002 08:37 PM
