What rearend ratio and stall? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2012, 07:41 AM
71 c10 weekend cruiser/highway NO drag strip with a 468 bbc and built th350 tarnny. Looking for some advice on what stall and if I need to change the rear gear I'm pretty sure (will know soon) the truck has 3.08 gears just wondering if I should change to a lower gear when I install the eaton posi? I am running a 30 inch rear tire also... Here are some specs...
Edelbrock Performer RPM intake, 1" spacer, HEI distributor, MSD plug wires, fully rebuilt heads with new valve springs, new seals,10 degree locks, retainers and lash caps, stainless steel valves (2.25I 1.88E), full roller rockers, JoMar stud girdles, new Comp Cams xm 278h-565 lift-234/244 dur @ .50 , forged SpeedPro pistons, ARP main studs, new rings, flowtech headers.
ALL suggestions/advice wanted!!!...Thanks
Old 04-10-2012, 08:18 AM
How fast is fast enough?
3.73's would make for better acceleration but may tmake highway rpm higher than you'd like. I would go with a simple 2000 stall.
Old 04-10-2012, 02:55 PM
So maybe a 3.55 rear gear?
Old 04-10-2012, 02:59 PM
F-BIRD'88's Avatar
Yada Yada Yada
3.73's and a 11" 2800stall converter.
Or the tighter low stall version of the B&M 10" holeshot B&M pn 20413
This converter is very street friendly behind a BBC.
Old 04-10-2012, 05:42 PM
Ditto, what I was thinking. The 30" tires would be ok on the Highway with 3.73's.
Old 04-10-2012, 09:50 PM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
Well if it was me ill goo fore 3:31 gears!
Old 04-11-2012, 09:20 AM
ogre's Avatar
the 'Duracell Project'
yes, with that motor and trans i would go to a 2:73 for cruising
you might actually be able to afford to drive it with that gear
Old 04-12-2012, 01:20 AM
With me using the Eaton posi it looks like 3.42 is the breaking point then I have to go to 3.73. What brand gear should I use or stay away from I had motive gear recommended to me any others?
RearEnd Ratio 36 Chevy Guy Hotrodding Basics 9 02-11-2011 10:04 AM
RearEnd Ratio 36 Chevy Guy Transmission - Rearend 1 07-29-2010 10:57 PM
Stall vs. gear ratio juiced66malibu Transmission - Rearend 6 01-10-2010 01:07 PM
rearend ratio yragat Transmission - Rearend 2 04-23-2008 07:30 AM
How do you tell rearend Ratio Bluegrass Transmission - Rearend 14 12-26-2002 01:56 PM
