what rearend will fit under a model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 04:34 AM
model-a's Avatar
Last journal entry: tools
Anyone know what rearend will fit under a model-a I think it measures 56.50 inches,and I think a maverick rearend will fit. I am going to remove the tork tube and run a open rearend. All help is appreciated
Old 02-08-2013, 07:32 AM
Wiki Edits: 27
model A parts swap
Be aware . Different years used different parts usually the 5 lug maverick is an 8 inch, Read up on the Wiki here on hotrodders on how to identify rear ends. My Roadster was built over 20 years ago, never completed . It has several things I don't like and plan on changing. The Maverick 8 in rear was installed with coil springs. NOT coilovers. the home made 4 bars used toyota tie rods. about the size of my pinky finger. the front has a 40's axle with more toyota parts. welds to the axle and various places on the frame. I have another frame I plan on using and will use different parts. and will sell the rolling chassis for a rat rod, My choices, I have a stock front axle, a 40's car front susp complete and a 46 lincoln front suspension with the good big drum brakes. Buick finn brakes in a box. and 40 spindles with 65 Mustang 4 piston disc conversions. For the rear I have a mustang 8 out of a 70, about 2 inch too wide, a 5.0 mustang "posi rear with 5 bolt disc conversions, I have located a 65 mustang K car in a wrecking yard with the 9 in rear, the owner just hasn't said what he wants for it. You can buy the various conversions pieces, just have to decide if rear coil overs or a leaf, Welder series sells a weld it yourself hot rod parts. I usually build all my own parts.,,, I have a mill, lathe , plasma, pattern cutter, etc.
Old 02-08-2013, 08:15 AM
delawarebill's Avatar
rear
where is that measurement coming from.. inside backing plate or to front of drum ??? i have a '67 mustang on my bucket, and i'm thinking its around 54" to the backing plates. the pre '67's have a reduced axle housing.. meaning at the diff it's 3" and drops to 2" at the backing plate... '67 is straight 3". my numbers may be off but u get my point..thats an 8" too..
Old 02-08-2013, 09:03 AM
kso's Avatar
kso kso is offline
Here's a chart. Rear End Widths Note the S-10 7.5 rr is not on there, it's 56" and suitable for only low-hp...but common. Most of the narrower factory rears that can support power (Maverick or Mustang II 8", Mopar A-body 8 3/4) have been picked or scrapped years ago so happy hunting. Btw all are measured from the wheel-mounting flanges.
The Following User Says Thank You to kso For This Useful Post:
model-a (02-10-2013)
would a 8.5 rearend fit under a 84 cutlass with a 7.5? brians407sbc Transmission - Rearend 7 09-21-2010 08:59 PM
Will a Ford Sport Track rearend fit? Turbonoma Transmission - Rearend 0 08-22-2008 10:02 AM
what rearend will fit in a camaro the ernster Transmission - Rearend 0 04-24-2003 10:45 PM
what seats fit a model coupe??? straycat60 Interior 7 03-31-2003 09:38 PM
Do I have to shorten the rearend to fit bigger tires? fireschenie Transmission - Rearend 7 12-26-2002 01:45 PM
