What are the recommended steps for refinishing a bumper? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 10:22 PM
I've got a used urethane bumper cover that I want to paint to match my car. It has the factory finish on it, but there are numerous small scratches, a couple of shallow dings and the clear coat has eroded away in places. I would like some opinions on what materials, grits and processes would be recommended. In the past I've completely stripped parts down to the plastic and then primed, wet sanded and sprayed, but I'm won dering if that's overkill. I'm planning on spraying Chomabase and Chromaclear sonce I already have all the materials on hand. Also, I need to repair the mounting brackets. The metal parts have sheared off at the bumper tabs. I was thinking of using duramix 4040, but would like opinions there as well. I realize that most would just replace the cover with new, but this is a limited production model and the new OEM part is out of my budget.
Old 02-09-2012, 04:13 PM
sounds like you did it right the first time, Over kill is good, do it once do it right
Old 02-09-2012, 05:02 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you have a method that works for you stick with it,,,
Sam
Old 02-09-2012, 11:55 PM
SEM makes some fillers that work on plastic bumpers. You need to know for sure the type of plastic, and use the appropriate product.
My understanding is that thicker paint and primer builds are more prone to cracking if flexed, my suggestion is to sand down base material, or close to it.
Bumper - Bumper - Bumper - Bumper - Bumper - Bumper - Bumper - Bumper - Bumper - Bump S10xGN Hotrodders' Lounge 15 02-01-2010 10:16 AM
Best recommended paint, and steps? 39chevy Body - Exterior 5 08-17-2009 07:56 AM
Plastic bumper refinishing MAUSS Body - Exterior 1 05-05-2008 12:08 PM
shortened bumper bumper arms slowpoke Body - Exterior 2 02-08-2007 07:34 AM
Caliper refinishing bonuts Suspension - Brakes - Steering 10 01-05-2005 09:34 PM
