what replacement bench seat will fit 57pickup
Hey guys, my 57 3100 truck came without a bench seat. Can anyone tell me what modern make/model/year trucks I can get one out of that will fit? Thanks.
Sorry rev, I missed the part where you said you didn't have a seat to begin with. You can always raise or lower the height of your seat with the brackets or even easier if you have adjustable height on your modern seats.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
One of the places to look is in the passenger vans as the center seat is usually shorter than the others.. Take your tape measure with you when you go shopping..those are even close to the right height for those older pickups..They work fine if you can accept a bench seat..
Sam
1955-59 Chevrolet stock bench seat dimensions
Don't know if Revedup is still around, but I went and measured mine for the record. ;
57-57 1/2" wide 12 1/2-13" butt to floor 18" front seat edge to backrest 31" floor to top of backrest 27" back of seat(wall side) to front of seat( I think the slider is still about midway) this dimension will vary according to slider position. olnolan |
Seats
I hate to disagree with you guys but there could be a new chev seat that will fit with out a lot of trouble.
I will give you an example, I took the seats out of my 46 Ford Coupe, Now I wanted to put buckets in front, so they were a little work I got the seats from a 98 Mark VIII, I had to make a little riser for them, then drill the holes in the riser to fit the floor holes, the back of the seats were right on, the front mounting tab was at a angle, so I drilled and tapped it to fit. The back seat, I lifted the back off of the mounting tabs, then took the bottom out, took the bottom of the mark put it in. It had a slight forward slope, so I put a 2x4 across hump, got it level and screwed it in the bottom now fit perfect. Then I took the back from the Mark, after mounting 2 safety belts from the Mark, and just slip the back on the mounting tabs. I didn't have to change a thing. They fit perfect over the wheel wells, the seats were no wider than the stock ones, now Henry was known not to change things if he didn't have to, so all was good. All change in less than a day. Bob |
| Recent Interior posts with photos |
| Bench seat for a 32 3 Wdw | reflog | Interior | 14 | 08-04-2011 07:13 AM |
| Replacement bench seat for 32 3wdw | reflog | Interior | 3 | 04-20-2011 12:35 PM |
| Bench Seat Swap To Bucket Seat Help | arnellwest | Hotrodding Basics | 11 | 03-28-2011 10:50 PM |
| Can this bench seat be salvaged? | C-10 | Interior | 10 | 01-18-2010 07:38 AM |
| elcamino bench seat | captjim40 | Interior | 1 | 03-08-2003 02:33 PM |
