What Is Reverse Flow Cooling? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2004, 04:49 PM
I seen a pair of heads for an LT-1 Corvette and someone said they were reverse flow cooling. What exactly is reverse flow cooling and how does it work? What is the advantage of this type of cooling? Thanks.
Old 05-19-2004, 04:52 PM
Tim240Z's Avatar
The coolant flows through the heads first, then the block. Keeps the heads cooler, less chance of detonation....
Tim
Old 05-19-2004, 05:05 PM
Are the water jackets in different locations? Or would these type of heads work on the older style small blocks? I'm told these are for '92 and up motors.
Old 05-19-2004, 05:12 PM
Tim240Z's Avatar
They can be converted to run with older blocks, but bolt on is only with the 92-96 LT1 engines.
Tim
DoubleVision's Avatar
While they will bolt on to older blocks, the cooling passages don`t line up, so no, they won`t work on older small blocks.
Old 05-19-2004, 06:01 PM
Can these be used on any '92-'96 small block, including 305's?
Old 05-19-2004, 06:10 PM
Tim240Z's Avatar
Only LT1 engines, unless you have the heads converted (drill coolant passages)
As far as I know the LT1 came in 5.7L, and 4.3L only (Camaro, Firebird, Caprice and Corvette).
Tim
Old 05-19-2004, 07:28 PM
What does the "LT-1" stand for, what is the difference between them and a regular 350?
Old 05-19-2004, 08:18 PM
Tim240Z's Avatar
Do a qweb search...there is pages upon pages of indepth info out there....try this for starters:
http://www.fierolt1.com/technical_documents_main.htm
http://www.autosite.com/garage/encyclop/ency02f.asp
http://www.n2performance.com/cgi-bin...10&action=Read
Old 05-19-2004, 11:50 PM
LT-1 (notice the hyphen) was the GM option code for the "special-high-performance" 350 offered in Corvettes & Camaros in the very early '70s. They used the same blocks as the low-performance 350's of the time, but made 60-70 more horsepower.
The '92-'96 LT1 (no hyphen) was also a high-performance 350, but it was based on a block with a different cooling system design (reverse-flow) from that of the standard 350's from the same period.
