Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What ring gear works with 700R4 & 350?
Old 12-19-2005, 09:13 PM
rwruther's Avatar
rwruther rwruther is offline
Last journal entry: new wires for the hot rod 39
I hear there are two "flywheels" that work with 700R4 and 350 Chevy engine. I just bought a used 700R4, a 92 Camero.... I did not get the ring gear and some other parts, the output shaft, the inspection cover.... How many teeth are on the gear? I have a ring gear sitting in the garage.... Only way I know how to tell is bolt it on and see if the starter makes it go... is there some other way?
Thanks a ton
PS I'm freezing here in Michigan! Garage is 21 degrees! Hurry up spring!
