-   -   What ring gear works with 700R4 & 350? (http://www.hotrodders.com/forum/what-ring-gear-works-700r4-350-a-76574.html)
rwruther 12-19-2005 08:13 PM
I hear there are two "flywheels" that work with 700R4 and 350 Chevy engine. I just bought a used 700R4, a 92 Camero.... I did not get the ring gear and some other parts, the output shaft, the inspection cover.... How many teeth are on the gear? I have a ring gear sitting in the garage.... Only way I know how to tell is bolt it on and see if the starter makes it go... is there some other way?
Thanks a ton
R
PS I'm freezing here in Michigan! Garage is 21 degrees! Hurry up spring!
302 Z28 12-19-2005 08:41 PM
The two flwheels are 153 and 168 tooth. You must combine the proper starter with the appropriate flywheel.
Vince
