What ring gear works with 700R4 & 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2005, 08:13 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
I hear there are two "flywheels" that work with 700R4 and 350 Chevy engine. I just bought a used 700R4, a 92 Camero.... I did not get the ring gear and some other parts, the output shaft, the inspection cover.... How many teeth are on the gear? I have a ring gear sitting in the garage.... Only way I know how to tell is bolt it on and see if the starter makes it go... is there some other way?
Thanks a ton
R
PS I'm freezing here in Michigan! Garage is 21 degrees! Hurry up spring!
Old 12-19-2005, 08:41 PM
302 Z28's Avatar
The two flwheels are 153 and 168 tooth. You must combine the proper starter with the appropriate flywheel.
Vince
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
350 Dead In Gear ArchonRacing Engine 7 02-14-2005 10:47 PM
pinion/ ring gear exchange chevyman06 Transmission - Rearend 2 06-24-2004 05:47 AM
Ring gear spacer 1981monte Transmission - Rearend 2 10-14-2003 04:59 AM
Cam gear Bronze Thrust Ring Rex Tribble Engine 10 10-22-2002 06:57 PM
