What rod/main bearing sizes on a 90' 305?
Rebuilding a 305 that I got from a buddy out of a 90' camaro RS and we pulled the crank off and the bearings looked a little scored so were going to replace all the bearings while it is out (cam bearings didn't look bad at all) and I was wondering how do I know what size I should get? I'm assuming I should just get std sized 2.1/large journal bearings but wanted to make sure by asking first, or if I should get undersized bearings since the engine previously had 175k miles on it?
Thanks for any help! |
Alright, I have a few mic's that I have had to use to measure like the valve stem seals already and proved to be pretty accurate, but I wasn't sure how the size that I read correlates to the sizes I see listed with the bearings which most of the time just have the undersize listed and not the exact size, or either that is the size of the inside of the bearing and not outside, etc. I guess I could always check the manufacturers website though for that info.
I will go take a look at the bearings in a little bit and see if I can find anything on them, thanks for the help so far. |
| Problem setting up guts of ten bolt | rwruther | Transmission - Rearend | 18 | 08-30-2007 10:07 PM |
| "tapered" rear axel bearing question | powerrodsmike | Transmission - Rearend | 3 | 08-10-2007 04:47 PM |
| Carrier bearing preload? | Sixshooter | Transmission - Rearend | 11 | 11-10-2005 11:35 AM |
| tiny little fish-scale-like flakes of bearing on bearing/journal | bullheimer | Engine | 2 | 04-16-2004 01:12 PM |
| s-10 carrier bearing, how do you check them | catscan4free | Transmission - Rearend | 2 | 01-24-2004 04:45 PM |
