Total timing (initial plus mechanical) should be all in between 2500-3500 RPM. Experiment to find what works best for your combo. The Total should also be the highest you can achieve without any ping and should be set with the vacuum advance hose dis-connected and plugged. As to where to hook up the vacuum advance; this again will be decided by you by experimenting. Some will say that you should use the Ported connection and others (myself included) will suggest using the Full connection.
My setup that works very well for my combo is as follows. 18 degrees initial, 38 degrees Total (with vacuum advance hose disconnected and plugged) all in by 2700 RPM. I use the vacuum advance on the Full manifold vacuum. This is with a stock GM HEI on a 350 Chevy engine. Cam is a Comp 280H Magnum. Rear gears are 3.80-1 with 28" tall rear tires. Vehicle weight is 2660 lb. |
I agree with Frisco. I have all my advance in by 2800 rpm (34 total, 18 initial) and my vacuum advance is connected to manifold (full) vacuum. This is on a 9.8:1 406 sbc with a Comp 280H cam. This was tested on an engine dyno. 3300 lb car
Steve |
