what sanding block for round panels sections - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2013, 09:56 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
So I'm fnishing up this chevy pick up that I shaved the tailights & tailgate so I need advice on what to use to sand it down its rounded so I need a flexible sander I have one of those cheapo bondo flexible sanders but since Im sanding up & down the paper won't stay on.Any ideas?
Please excuse any typos or terseness: this email was sent from my mobile and I have clumsy fingers.
Old 09-23-2013, 10:13 PM
I have to tell you, this is my personal opinion on my methods and like they say, there are many ways to skin a cat. But I don't like those flexible sanders, not for something like that at least. A long gradual curve like a 50 Chevy front fender top, yeah, but not something that tight. The reason is it doesn't maintain the shape, how in the world can you block a shape when the block isn't that shape?
Here you go, are you ready for my method? I don't think you are, sit back and have a beer.
Outside of the con-caved area above the deck lid at the belt line, I did every single panel on this car with a flat block.
You can't tell very well from these photos but above the tail lamps that area is literally as round as half a third of a bowling ball, literally. Outside of that area above the deck lid which I started shaping using a brand new roll of paper towels as a block! Finished with a large rubber hose.
But the rest of the car was entirely done with flat blocks and regular old 17.5 inch long boards. The whole rear corner "bowling balls" and all the tight compound surfaces were done with a 5" rubber block, a good old rubber block.
Now, how in the world did I do this? I use a very simple concept , I look at the rounded surface as a "curved flat".
Yep, just as I would block a flat area and feel for a high spot then block it out, I feel the curved areas exactly the same, I feel for a high spot rubbing my hand over the surface just as I would a flat area, when I feel that high spot I sand it "flat" with a curved motion sanding JUST that high spot. I repeat this over and over until it's "flat". When it's "flat", well then it's a perfect curve!
Feeling it is WAY more important than some magic block can do in my opinion.
The Following User Says Thank You to MARTINSR For This Useful Post:
cutthroatkid (09-24-2013)
Old 09-23-2013, 10:21 PM
Faith - Respect - Trust
X2 on what Brian said Cut...those flexible sanders, boards or whatever, I never use them...my favorite tool in the box is the long board.
Ray
Old 09-23-2013, 10:39 PM
put up or shut up
I agree with flexible blocks. There's really little need for it. I could possibly see something being useful with those blocks but I don't use them. It's more important to get the longest and straightest block on there possible and situating the block so you're not digging in anywhere, so block position and sanding strokes will help you out better than just picking up a flexy block. If I need a round block it's usually the area right below body lines and I will use a long piece of pvc pipe but most times I will use the edge of my block. If it's really rounded and a compound curve I'll just use a rectangle dura block. Sometimes I'll even use the narrow edge of it to avoid digging into compound curves but hardly use round blocks and never use flexible blocks.
Old 09-24-2013, 05:20 AM
mitmaks's Avatar
Last journal entry: Grille
Get a set of Durablocks, they have every block for all your sanding needs.
Old 09-24-2013, 06:19 AM
Mitchman's Avatar
Grand Master of the Universe
X2 on Durablocks, and learn to criss-cross in 3 directions on every surface. Use different color primers if possible or Guide Coat in a rattle can to check your progress.
Old 09-24-2013, 08:34 AM
LOL, I come from the days before self adhesive paper and Durablocks, they didn't exist. I used a good old 3M block and a long board, that is all I had. I cut a 3M block to make narrower ones and this worked great!
I do have a few Durablocks now and they ARE very nice. To have a drawer full of them in your box would be a great way to go.
Old 09-24-2013, 11:35 AM
two cups of tea
Wiki Edits: 2
haha I have the smae exact blocks they were my grandpas
Old 09-24-2013, 11:41 AM
two cups of tea
Wiki Edits: 2
when I first got serious about this I got durablocks I also keep a couple rattle cans of black laying around to find my low spots.I just finished the 73 challenger last night. unfortunately best fellas battery was shot & I couldn't get it outside to take a good picture so hopefully he will send me one, I'm still working on this custom C 10 and I'm on a 300 C a 2011 Lexus a couple bikes & a freakin Viper!
Old 09-24-2013, 03:15 PM
JeffB's Avatar
CHeck this out:Block Sanding
Old 09-24-2013, 09:28 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Brian, I think he is saying you are OLD
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
MARTINSR (09-24-2013)
Old 09-24-2013, 10:22 PM
Are you calling me an old man!
I am a Grandpa so it's ok.
Mus-tash Grandpa, Mus-tash.
Old 09-24-2013, 10:25 PM
That's some good stuff. I may disagree with the flexible sanders but people use them so it's just an opinion of mine. That is some very good stuff on blocks!
John long (09-25-2013)
finally a good round block! tech69 Body - Exterior 7 07-27-2012 04:29 PM
Block Sanding help again danny_g Body - Exterior 16 08-12-2009 10:24 PM
BLOCK Sanding dyna block or LONGBOARD?? D9ZZ Body - Exterior 6 06-26-2008 08:10 AM
O-rings in Brake Distribution Block, Square or Round and Material? Scode68 Suspension - Brakes - Steering 4 12-31-2007 07:16 AM
Sanding Block Man586 Introduce Yourself 2 07-27-2004 07:16 PM
