hi, i am streetrodding a 30 ford coupe. does anyone know what seats will fit this car? it is small and narrow inside. i was told the shorter bench seat from the middle of a caravan would fit, but they seem too wide. i like the bench seat better, but will use buckets if i have to. i would appreciate any help. thanks!!!!!! mike
Arm yourself with a sketch and a tape measure and make it down to your local "pickapart" junk yard.
If the short van seat is closest you can modify it length-wise without too much trouble and still keep it's good upholstery for awhile if you want.
i used a seat out of a 73-79 ford pickup in my 30 model a coupe. just remove seat cover and foam, cut metal frame and weld. cut same amount out of foam, glue together. a electric carving knife works perfect for cutting foam. the completed seat can be made in less than an hour , and works perfect. hope this might help.
I used buckets seats out of a 78 Chevy van in my 31 coupe. They touch in the center so it looks like a bench seat. You have to make your own mounts but these seats are low back so they don't block the back window. I hope this helps
Just got a set of Mazda Miata buckets for my 1931 coupe project. They fit across just fine but I am going to have to raise them up from the floor. Been told Scats fit also and school bus seats work. The middle seat from a carvan work. Measure higher up than floor. You find a little more width. I believe anything 40" or less will work.
I used a set of TR3 or may be it was a TR4 (one or the other) they came out of a roadster and they were Black Leather and pleated with a Red piping they were very nice and looked really good.
Gene Neal
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
