What is this set up called? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-31-2012, 01:14 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
What's wrong with the floater setup? If I were going to put coil over suspension on it I think I would rip that whole set up out and start from scratch. A 4 bar, panhard bar and move the coil overs out as far as I could for a little better handling.
  #17 (permalink)
Old 08-31-2012, 10:41 PM
Thats not what i want to do, and not what Im asking about. Does anyone know if i can mount coilovers in the same positions as my current shocks while eliminating my leaf springs??
  #18 (permalink)
Old 09-01-2012, 09:59 AM
S10xGN's Avatar
Gotta love a turbo!
I'd say yes, as it appears the ladder bars have their own mounting points, crossmember and diagonal bar. Try removing the leafs and see how stable the axle is. Do you have enough clearance for the coilover springs? They are quite a bit larger in diameter than a standard shock...
Russ
  #19 (permalink)
Old 09-01-2012, 10:18 AM
Russ
Clearance is not an issue. Im wondering if I can use the existing bolting method (that my shocks utilize) with the coilovers. Or if it is not supportive enough. I know the ladder bar with diaggonal bar will work cause thats how most companies (Chris Alston chassis works, Q1A) sell their suspension kits. My worries is if i need to weld in mounting tabs or if the both through frame method will work and be strong enough.
  #20 (permalink)
Old 09-01-2012, 11:02 AM
S10xGN's Avatar
Gotta love a turbo!
Not being able to see the upper mount, I couldn't say. However, since you will be supporting the entire weight (percentage of whole) of the car, it will need to be quite strong.
Russ
  #21 (permalink)
Old 09-19-2012, 08:01 PM
Just an update, I removed the leaf springs and went with the coilovers, the rear of the car seem to sway going straight down the road. Do I need more tension on that lateral bar between the ladder bars?
  #22 (permalink)
Old 09-19-2012, 09:46 PM
Wiki Edits: 27
testing time
With the car up on jackstands see how much side to side movement you get at the rear axle. With the Heims you are using there shouldn't be any , the ladder bars and diagonal bar might be flexing. if so a Panard bar like you posted might be better. , as long as possible and parallel to the ground at ride height,
  #23 (permalink)
Old 09-19-2012, 11:01 PM
evolvo's Avatar
Look around here: http://www.artmorrison.com/rearsusp-kits.php Art Morrison is one of the best in the business!
What are these called????? 71haulnazz Engine 9 09-18-2008 03:57 PM
What is it called? rumrumm Interior 3 05-11-2007 02:10 PM
What is this called? MoparGuy Garage - Tools 7 02-14-2007 12:32 PM
What is this called? EazyDuzIt102 Engine 44 10-11-2005 10:11 PM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 09:45 PM
